Five lug fox body front brakes wanted
2L8ULOST
ThndrChkn
dirt_worker
Five lug fox body front brakes wanted Empty Five lug fox body front brakes wanted
Post  dirt_worker October 23rd 2010, 1:27 pm
Wanted...five lug fox body front disk setup. What have ya'll got? Would really like aftermarket but will definitely use oem to keep costs down.
Thanks,
Mike
dirt_worker
dirt_worker
Five lug fox body front brakes wanted Empty Re: Five lug fox body front brakes wanted
Post  ThndrChkn October 25th 2010, 8:16 pm
Hey Mike. Are you doing a conversion on your truck? If so, I used the front brakes from a Lincoln MK VII. They're 5-lug, and they're bigger than the std. Foxbody rotors as far as OEM stuff goes. And they're pretty reasonably priced too at O'reilly's or Carquest.
Doug... Cool
ThndrChkn
ThndrChkn
Post  dirt_worker October 26th 2010, 8:28 am
Excuse my ignorance, but will they fit my fox mustang spindles? Is the rotor and hub one piece?
Thanks,
Mike
dirt_worker
dirt_worker
Post  ThndrChkn October 26th 2010, 9:25 am
Yep, my truck has 93 Mustang GT Spindles on it. Let me check, but I think the spindles have to be from the later Foxbody's for proper fit. I'll let ya know as soon as I find out.
Doug... Cool
ThndrChkn
ThndrChkn
Post  ThndrChkn October 26th 2010, 9:45 am
Yes Mike, the spindles do have to be from the 87-93 years due to the little extra length of the spindles so they can clear the caliper mounts of the MK VII.
Doug... Cool
ThndrChkn
ThndrChkn
Post  dirt_worker October 26th 2010, 11:40 am
Thanks doug, what year MK VII are we talkin?
dirt_worker
dirt_worker
Post  ThndrChkn October 26th 2010, 11:56 am
I think they were the same as the later Fox's. 87-93... Keep in mind too though, I put a complete Foxbody front suspension on the Banana. I'm not sure how everything will work if you're just trying to do a brake swap. scratch
Doug... Cool
ThndrChkn
ThndrChkn
Post  2L8ULOST November 7th 2010, 8:14 pm
for a cheap alterantive i used some rotors from autozone ask for 1986 mustang svo 4cylinder front brakes the are the one piece direct bolt on to the 87-93 front v8 spindles and are 5 lugs and are affordable.
2L8ULOST
Post  IDT-572 November 10th 2010, 12:47 am
Mike the MK VII are what is on my 86. I had to get the spindles to make it work................ Worked good.
Post  bbf-falcon November 10th 2010, 3:16 pm
2L8ULOST wrote:for a cheap alterantive i used some rotors from autozone ask for 1986 mustang svo 4cylinder front brakes the are the one piece direct bolt on to the 87-93 front v8 spindles and are 5 lugs and are affordable.
I always thought that they were all(mustangs) 4 lug until 94 Surprised
Post  BigBlockRanger November 10th 2010, 4:10 pm
SVO's were 5 lung and are not exactly the same as the 87-93 V8 stuff.
79-86 & 87-93 4 cyl cars - all use the same rotors & spindles (exc. SVO which had unique spindles and brake calipers) 5 lug Ranger rotors can be used as a retrofit for 5 lug wheels.
87-93 V8 models had larger rotors, different spindles AND struts. The spindles have a thinner mounting flange for the strut. Lincoln Mark VII 5 lug rotors can be used to convert to 5 lug.
Post  johndickjr November 11th 2010, 8:15 pm
another super cheap way , is to use ford ranger rotors, i used them on my stang, it ran 11.40's at 121 at stopped fine
johndickjr
