5 lug conversion on drum brakes for a Fox Body
61coon
DanH
5 lug conversion on drum brakes for a Fox Body  Empty 5 lug conversion on drum brakes for a Fox Body
Post  dfree383 June 25th 2014, 11:11 am
Are there and 5 lug drums available to use on the stock 8.8 4 lug drum brakes?
5 lug conversion on drum brakes for a Fox Body  Empty Re: 5 lug conversion on drum brakes for a Fox Body
Post  DanH June 25th 2014, 11:16 am
dfree383 wrote:Are there and 5 lug drums available to use on the stock 8.8 4 lug drum brakes?
check Vic's and Lincolns,
DanH
Post  61coon June 25th 2014, 11:36 am
Early model rangers 8.8 drums will work. Use (2) drivers side axles out of the ranger for a 5 lug axle swap as the ranger is an offset housing and the fox isn't.
61coon
61coon
Post  dfree383 June 25th 2014, 11:40 am
We are going to get a Strange Spool, Axle and C-clip eliminator package, so I won't need Axels.
So 80's Ranger Drums?
or 80's / 90's vics?
I can reuse my brakes and just put the drums on? I don't need to get the complete set-up?
Post  61coon June 25th 2014, 11:49 am
I'm not sure about the Vic's, but I know for a fact the ranger drums will work. Done it many times. 8.8 ranger
61coon
61coon
Post  dfree383 June 25th 2014, 11:51 am
61coon wrote:I'm not sure about the Vic's, but I know for a fact the ranger drums will work. Done it many times. 8.8 ranger
Cool Thanks
Post  61coon June 25th 2014, 11:53 am
No problem Dave. I threw the axle part in there for others to know too. If you ain't running big hp it's an easy stock swap.
61coon
61coon
Post  whitefield June 25th 2014, 1:34 pm
Doing one right now Dave if you need the part numbers . I also will have the correct rotors too. we are changing over to the sn95 front brake calipers spindles and rotors.
whitefield
whitefield
Post  whitefield June 25th 2014, 1:40 pm
7.5 axels are the same spline as 8.8 and work in the 8.8 from mustang to mustang
Ranger and ford aerostar van drums and axels
Lincoln mark VII front rotors
If I remember anything else that will interchange I will post up.
whitefield
whitefield
Post  Bill Heard June 26th 2014, 12:11 pm
Would all this stuff work on 84 Thunderbird too?
Bill Heard
Bill Heard
Post  83-88T-Bird Guy June 26th 2014, 2:48 pm
Bill Heard wrote:Would all this stuff work on 84 Thunderbird too?
83-88 T-Bird/Cougar axles are 3/4 inch longer each side. ( 1 1/2 in. wider overall)
Yes, the Ranger drums (and Ranger axles ) will fit the T-Bird, but it will move the wheels inboard 3/4 inch each side. (making it the same overall width as a Fox Mustang rear end)
A Lincoln MK VII rear end is the same width as the 83-88 T-Bird.
94-98 Mustang rear is the same width as a 83-88 T-Bird.
As posted above, Lincoln MK VII front rotors or 94-95 SN95 Mustang spindles and brake setup.
83-88T-Bird Guy
83-88T-Bird Guy
Post  Doug Rahn June 26th 2014, 6:03 pm
You can get them here Sand Man  Laughing Laughing I for got to add they have the axles too if you need them.
http://www.latemodelrestoration.com/products/79-93-Mustang-Brake-Rotors-And-Drums
