Swapping a traction lock into my 10.25" Sterling
Swapping a traction lock into my 10.25" Sterling Empty Swapping a traction lock into my 10.25" Sterling
Post  Greg_P October 27th 2010, 10:59 am
Ok, I rebuilt the traction lock in the sterling once, and now it's slipping bad again. I have a known good traction lock in another sterling rear I have here, but it is from a 1989 F250 vs. my 1995 F350.
Will the differentials swap over between housings?
Thanks,
Greg
Greg_P
Greg_P
Swapping a traction lock into my 10.25" Sterling Empty Re: Swapping a traction lock into my 10.25" Sterling
Post  TorinoGT October 27th 2010, 1:26 pm
I cant say from experience, but I believe all 10.25 axles are the same EXCEPT for a pinion change at some point in the early 90s... (then of course the 10.5 rear has its differences)
Shane
TorinoGT
TorinoGT
Post  schmitty October 27th 2010, 1:27 pm
From what little I know, isn't there two different Sterling rears? I don't know for sure, but I thought there was a 10.5 Sterling also, but I'm not sure what it was in. I would make sure that they are the same, otherwise it should fit. Cool
Post  schmitty October 27th 2010, 1:31 pm
Got beat by Shane. Embarassed
Post  Diggindeeper October 27th 2010, 8:05 pm
Cases are the same between the short and long pinion 10.25's
And are the same as the 10.5's EXCEPT if the 10.5 has a 3 pinion set.
Diggindeeper
Diggindeeper
Post  Greg_P October 30th 2010, 6:58 am
Thanks, guys!
Greg
Greg_P
Greg_P
