which oil pan for a460 block?
+6
Wheelie58
tconnection
10 posters
which oil pan for a460 block? Empty which oil pan for a460 block?
Post  tconnection October 28th 2010, 12:58 pm
Is there any issues with the moroso Eliminator-1 pan fitting on the a460 block? What about the canton drag race pan?
tconnection
which oil pan for a460 block? Empty Re: which oil pan for a460 block?
Post  dfree383 October 28th 2010, 12:59 pm
most typical off the shelf pans will require some fitting of the pan or machining of the outer edge of the caps to fit from my experiance.
Post  Lem Evans October 28th 2010, 1:04 pm
What Dave said is correct.
The part # will depend on the chassis the engine is going in.
Post  bruno October 28th 2010, 8:20 pm
tconnection wrote:Is there any issues with the moroso Eliminator-1 pan fitting on the a460 block? What about the canton drag race pan?
have you thought about getting one of Lem's custom pans ?
http://WWW.CKRME.COM
Post  tconnection November 1st 2010, 1:45 pm
Im having to exchange my canton pan kit in from where i bought it from. I was told that the Moroso #20625 wouold fit just fine. I figured i would check with u guys also. Oh, trust me i would of gotten one of Lem's pans but i already had this one and just got my block friday.
tconnection
Post  David Cole November 1st 2010, 2:25 pm
tconnection wrote: I was told that the Moroso #20625 would fit just fine.
Not exactly. The Moroso steel pans 20625, 20614 and 20620 all use the same pan rail. On my last engine I had to have the 3 4 bolt caps milled for clearance. The pan would sit down on the block, but the caps kept it from lining up with all the bolt holes. You can either dent the pan at those locations to make it fit or do as I did and get the main caps milled. Took .050 off the side of each 4 bolt cap. Made the 20614 pan fit.
which oil pan for a460 block? Capmilled2
which oil pan for a460 block? Empty Shutter bug
Post  Wheelie58 November 1st 2010, 2:31 pm
Wow David,
Maybe you missed your calling. Instead of a race car driver, you should have been a photographer!
Nice detail.... Cool Keith
Wheelie58
Wheelie58
Post  bbf-falcon November 1st 2010, 5:49 pm
I had my machinist do what David did,and it worked just fine.
Post  tconnection November 2nd 2010, 4:47 pm
Ok, sounds good to me. I may just carefully touch them with a die grinder before i send it to the machine shop.
Thanks alot men.
tconnection
Post  138 November 2nd 2010, 5:09 pm
tconnection wrote:Ok, sounds good to me. I may just carefully touch them with a die grinder before i send it to the machine shop.
Thanks alot men.
pay the 50 bucks and let them mill the caps
138
Post  Lem Evans November 2nd 2010, 5:17 pm
Be sure to keep the cutting 1/16"-3/32" above the pan rail.
Post  bbf-falcon November 2nd 2010, 6:53 pm
Thanks alot men.
My machinist charged me $20 Smile
Post  richter69 November 2nd 2010, 7:55 pm
HeRo's get um done for free.............. Wink
Post  the Coug November 2nd 2010, 8:03 pm
I just machined my own.....
Post  138 November 2nd 2010, 8:09 pm
the Coug wrote:I just machined my own.....
real hEROs have their own mill.... bounce
138
