So what will I gain
frank13
So what will I gain
Ok so my current build is as follows:
466 with PI heads with larger valves
stealth intake
10.5:1 compression
hydro flat cam 600 lift
So i am thinking of changing to a scj or tfs or edel head.....I almost have all the cash for new heads....but what i want to know is what kinds of power gains will i see with each of those heads...is it worth it if dont change cams to a roller cam...or a solid flat cam....is it worth dropping 2k for this increase...I want a nice bang for the buck......is it worth changing intakes to a victor or stealth domi specific intake..(i have a domi sitting in the garage ready to bolt onto the steatlh 4150 intake with an adapter plate...
sorry for the rambling questions, but i dont wanna drop 2 to 2500 bucks on a small improvement ....
car is a strip/limited street time 2002 mustang gutted stock suspension drag radial car .....oh i wanna do a bolt on deal, no machine work type deal, heads will be out of the box with no port work right now
stealth intake
10.5:1 compression
Re: So what will I gain
The head deal is an investment................you might shout at the Coug, he has a set of Charlie Evans ported TFS streets and a matched victor intake I think...............as far as improvemnet its hard to say.....it wont slow down thats for sure and will give you room to grow....plus lose 80#s.
IMO.the Roller will be a big improvement. I will NEVER build a engine over 600hp again w/anything but a roller setup. But thats just me,everyone might not feel that way.
so what do think is the best bang for buck....cam or heads???
i dont wanna just throw money at it. i want to make a nice informed purchase...I have a realistic budget to improve the motor of about 2k
My pick would be cam if your PI heads are up to snuff.frank13 wrote:so what do think is the best bang for buck....cam or heads???
i guess i could do a solid roller cam and lifters and a set of procomp heads?????
Do the heads, It will give you more bang for the $$$ than a roller cam, Ford Racing SCJs are pretty cheap right now.
Your heads to FRPP Super Cobra Jet heads with back-cut intake valves and the correct intake notches in YOUR pistons is probably about 70 horsepower with NO other changes; (well, the additional cost of pushrods too, because they are a different length).
Only you can decide if it would be worth it or not...!
rmcomprandy wrote:Your heads to FRPP Super Cobra Jet heads with back-cut intake valves and the correct intake notches in YOUR pistons is probably about 70 horsepower with NO other changes; (well, the additional cost of pushrods too, because they are a different length).
So i notice on the scj's that they are 72cc combustion chambers.....they pi heads i have are 88....and I have about 10.5 to 1 compression, the scj will give me 12.17 ish compression....will that be ok with pump gas?? Are teh scj's the best way to go? or can i get a thicker gasket (using .042 now) to drive it down a little
You can get up to .120 gasket's from Lem.
res0rli9- BBF CONTRIBUTOR
res0rli9 wrote:You can get up to .120 gasket's from Lem.
But that will kill your quench area which will in turn cause problems with pump gas.
The Pope- Posts : 126
frank13 wrote:rmcomprandy wrote:Your heads to FRPP Super Cobra Jet heads with back-cut intake valves and the correct intake notches in YOUR pistons is probably about 70 horsepower with NO other changes; (well, the additional cost of pushrods too, because they are a different length).
Your question never said ANYTHING about a requirement to use "pump swill" as you claimed it to be a "mostly STRIP" car..
In that case you have ONLY the Edelbrock 95cc combustion chamber heads to fit your needs.
or Blue Thunder has a big chamber head.
IMO if it primarily a strip car.... Get the compression up and let it eat race gas.
» piston lightening
» Is this adequate gain with the SCJs
» what kind of hp gain
» HP gain guestimate
» How much would I gain from changing heads? VID!
