piston lightening
piston lightening Empty piston lightening
Post  STR-LGL-70 January 25th 2017, 8:44 am
This is for a boss 351 replacement piston not BBF but it should still apply so I am posting this here. I have a nib set of 30 over pistons and thought someone on here would know the approximate cost of weight reduction, or even if it is worth attempting.
Thanks, Sheldon
STR-LGL-70
STR-LGL-70
piston lightening Empty Re: piston lightening
Post  dfree383 January 25th 2017, 10:38 am
If you have a mill and a piston vice you could do a little lightning.
If not and you think you need a lighter piston, I'd sell those and get a modern piston that's lighter, better ring pack etc.
Post  STR-LGL-70 February 2nd 2017, 4:15 pm
Thanks dfree,
Mainly concerned w/weight as it relates to rod stress. I also have new "service" 351 c rods with I believe have ARP hardware and trying to use what's on hand. Have most everything to put together a nasty 351C for a '71 boss clone.
Sheldon G
STR-LGL-70
STR-LGL-70
piston lightening Empty Little gain
Post  ED468 February 6th 2017, 2:13 am
Be aware it takes a shit load of aluminum to even take out 5 grams. I bought a set off hear ten yrs ago that was suppose to be slightly used, the TRW .400 domes and two of them where 12 grams heavier. Don't think they where a set lol. Anyway gave up after removing like 2 grams. Now if I didnt care to weaken the piston thats another story.
ED468
Post  Scott Foxwell February 6th 2017, 9:14 am
I don't think I would just go in and start milling on a set of pistons. I'd send them to someone like Rebco who understands and knows just where and where not to take material out.
Post  rmcomprandy February 6th 2017, 12:35 pm
STR-LGL-70 wrote:This is for a boss 351 replacement piston not BBF but it should still apply so I am posting this here. I have a nib set of 30 over pistons and thought someone on here would know the approximate cost of weight reduction, or even if it is worth attempting.
Thanks, Sheldon
The cost would be very objectionable compared with the value of a regular replacement set of pistons.
Just buy lighter pistons to begin with.
