Piston?
Piston?
Does any piston manufacturer make a stroker bbf piston with cj and Scj valve reliefs as a shelf item?
lance flake- Posts : 142
Re: Piston?
Not that I am aware of.
Most of us are not fans for dual valve reliefs. The closest I get is a pocket that will take the stock head and an AFR.
You can have the SCJ pocket cut in most pistons, if you really need it.
I ahve to qualify even that.....I'm changing mine to three part numbers, one for each head.
Mark O'Neal- Posts : 286
Re: Piston?
Thanks Mark. I’m not the biggest fan of that either. Got a guy not sure on Heads but wanting a rotator.
Re: Piston?
lance flake wrote:Thanks Mark. I’m not the biggest fan of that either. Got a guy not sure on Heads but wanting a rotator.
Ain't it fun?
Most BBF piston are made on BBC forgings so they're a bit thick in the top. You should be able to add the SCJ relief without issue. It gets a little thin at the corner of the valve relief pad, but it's workable.
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
» Piston ???
» TRW 2443-N .030
» Piston
» P51 466 piston
» Piston ???
» TRW 2443-N .030
» Piston
» P51 466 piston
