Battery disconnect placement
bigblok2000ranger
frank13
Battery disconnect placement Empty Battery disconnect placement
Post  frank13 November 12th 2010, 2:10 pm
2002 Mustang
Battery in the rear on passenger side
need to add a battery disconnect....
I cant find a good spot to add it to the rear of the car (if someone has a good idea let meknow)
I was wondering if I can add it to where the fuel door (not used) is..basically looking to make an alum plate to put over the hole for the fuel door....
the rule book says rear of the car behind the rear tire...is this legal????
frank13
frank13
http://www.frankskinkracing.com
Battery disconnect placement Empty Re: Battery disconnect placement
Post  bigblok2000ranger November 13th 2010, 11:37 pm
You could use a pushrod style switch and mount the actual switch to the rollcage bar.
bigblok2000ranger
bigblok2000ranger
Post  BigDave65 November 14th 2010, 1:29 am
I don't think it would be legal inside the fuel door. Do like ranger said, mount it inside the trunk and use a push/pull rod out the back. It must be installed so it Pushes Off, and clearly labled that way. That makes for a slick looking setup.
BigDave65
BigDave65
Post  Doug Rahn November 14th 2010, 7:48 am
Mines not an '02, but I positioned it so the push-rod came out between the right side taillight and license plate. Then had a custom tag made with large Push Off on it. The location also made it easy for me to run a Morse cable up front so the driver can easily turn on or kill the power.
Battery disconnect placement DSCF0468
Battery disconnect placement DSCF1036
Post  whatbumper November 14th 2010, 11:49 am
Doug Rahn wrote:Mines not an '02, but I positioned it so the push-rod came out between the right side taillight and license plate. Then had a custom tag made with large Push Off on it. The location also made it easy for me to run a Morse cable up front so the driver can easily turn on or kill the power.
I like that setup. Heck, I may even change mine to something like that.
Post  BigDave65 November 14th 2010, 12:32 pm
Thats a slick setup there Doug. I like the idea of having the cable to switch it from inside the car. Are you able to switch it on and off from inside, or just off? Never knew if the cable could switch it to the on position.
BigDave65
BigDave65
Post  Doug Rahn November 14th 2010, 12:50 pm
BigDave65 wrote:Thats a slick setup there Doug. I like the idea of having the cable to switch it from inside the car. Are you able to switch it on and off from inside, or just off? Never knew if the cable could switch it to the on position.
You can switch it Off/On. I copied my parachute release lever and mounted it next to the shifter within easy reach. I had the Morse push/pull cable custom made for me at Midwest Control Products using their online design program. Somebody posted a while back that Lokar copied my design pirat .
Battery disconnect placement DSCF1275
Post  '65 T-BOLT November 14th 2010, 1:07 pm
very nice Doug
'65 T-BOLT
'65 T-BOLT
Post  bigblok2000ranger December 14th 2010, 7:51 pm
Very good idea there, only thing I would have done different was makes the bracket double shear to mount the handle but then again I like to over-do things sometimes. I remember B&M used to sell Morse style cables in different lengths in 6 inch increments all the way up to like 40'
bigblok2000ranger
bigblok2000ranger
