Spring wt Location tag
I have some coil over rear shocks from QA1 Motorsports. Where can you find the spring wt rating on these springs? I dont see a tag or nothing.
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: Spring wt Location tag
Tore,
They might be etched on the bottom flat seat part of the springs. Most have a metal tag wrapped around a coil on the spring, some are engraved into the bottom.
Travis
Travis
TravisRice- BBF CONTRIBUTOR
I remember you said about a tag Travis but no tag. Guess I will take it apart.
Thanks Tore
Thanks Tore
Tore- Posts : 865
Some cheaper and/or older springs out there might not have any tags/markings on them at all. If this turns out to be the case on your springs you can either take them to someone to have them tested to find the spring rate. Or you could get a close reading of the spring rate with a bathroom scale & a drill press.
DILLIGASDAVE- Posts : 2262
some of the cheaper ones is color coded
» Rear Spring Pigtail Location?
» Affect of valve spring install height on spring rating..
» spring cups or spring isolators?
» 1990 lx mustang body no title SOLD THANKS
» 2006 brush guard (sold)
