vertex mag hook up
vertex mag hook up
just picked up a nice vertex mag, it has a place for a wire close to the cap..i am guessing its for the ground to kill the power, then at the top of the shaft is a threaded part, again i am guessing that's for a mechanical tach drive
johndickjr- Posts : 896
Re: vertex mag hook up
You are correct John. I have a rev limit box and another mag that has a bad condensor if you need them I will sell them cheap.
will the box work on any mag, i forgot to say that this is for a straight 6 240-300 ford that i am building..lol, just picked up a forged crank today, and rods, i have some arias dome piston for it too, and a alum Clifford 4 barrel intake, going with a .580 lift 292 dr solid cam(unless i find a solid roller) will the box work with a shift lightbbf-falcon wrote:You are correct John. I have a rev limit box and another mag that has a bad condenser if you need them I will sell them cheap.
I will look at the box and see if it will work,and I should have the shift light that goes w/it.
I've hooked up a Vertex on a car before using a relay that was controlled by the key switch. It worked slick and I just had it so that the NC contact was connected to ground and then when the relay was energized by the key switch it would open the contacts and unground the mag.
DaveMcLain- Posts : 399
» Do i need to hook up a starter relay
» hook me up
» shifnoid hook up
» House of Hook
» trans filter hook up
» hook me up
» shifnoid hook up
» House of Hook
