*new set-up 521 to 562*
+6
138
Mark Laczo
badsnake306
10 posters
*new set-up 521 to 562* Empty *new set-up 521 to 562*
Post  badsnake306 November 22nd 2010, 5:13 pm
well originally i took a 521 a429 headed motor on trade and had to completly rebuild it. not something i wanted to do but since i had to rebuild it i basically started from scratch and pretty much upgraded everything.
engine:
A460 block bored to 4.560
4.3 scat 4340 crank
6.8 eagle H-beams L19 bolts
arias gas ported pistons
lem speced solid roller
danny bee
ati damper
crank trigger
billet fab two piece external wet sump pan
moroso mandrel and external pump
motorsport A429 heads 2.25/ 1.76
nex-tec springs
jesel pro series shaftmounts
7/16 cv pushrods
ported victor intake/ 1150 holley hp
hoping to have engine on dyno at the end of feb
badsnake306
*new set-up 521 to 562* Empty 562
Post  Mark Laczo November 22nd 2010, 5:54 pm
Looks good, you got any flow numbers for heads ? & Comp ratio ? Cam specs unless they are secret LOL ?
Later Mark
Mark Laczo
Mark Laczo
*new set-up 521 to 562* Empty Re: *new set-up 521 to 562*
Post  badsnake306 November 22nd 2010, 9:08 pm
Im not quite. Sure what to run for compression. Im thinking 15:1 . I wanna see how much power I can get out of my a429s
badsnake306
Post  bruno November 22nd 2010, 9:21 pm
cool build ...thats what we went to ...a 521 to a 562 ...cant wait to see the numbers
good luck
http://WWW.CKRME.COM
Post  badsnake306 November 23rd 2010, 10:44 am
my machinist suggested me to run GRP rods since the car is only going to be for track use. Is there a real advantage to aluminum rods. My plan is to build a bullet proof bottom end and upgrade my top end when i can. i really wanna run profiler heads because eventually i wanna make over 1000hp on motor.
badsnake306
Post  res0rli9 November 23rd 2010, 1:07 pm
badsnake306 wrote:my machinist suggested me to run GRP rods since the car is only going to be for track use. Is there a real advantage to aluminum rods. My plan is to build a bullet proof bottom end and upgrade my top end when i can. i really wanna run profiler heads because eventually i wanna make over 1000hp on motor.
Here's your heads http://www.460ford.com/forum/showthread.php?t=149955
Post  badsnake306 November 23rd 2010, 1:40 pm
i wish i could buy those. they are alittle out of my price range right now. i actually bought my oil pan and pump from brian. ive seen those heads in person very nice looking stuff for sure
badsnake306
Post  badsnake306 November 30th 2010, 9:32 am
well i got my A460 block over the weekend. what a beefy piece for sure. just notice that on the #2 main web there is a serious casting imperfection. i wonder if anyone elses block was like this but here are some pics finally
*new set-up 521 to 562* Mattsblock1
*new set-up 521 to 562* Mattsblock2
*new set-up 521 to 562* Mattsblock3
badsnake306
Post  badsnake306 November 30th 2010, 9:36 am
i ordered my pistons. i decided since there was no different in pricing on the 4.56 pistons to 4.600 pistions i obviously went with the 4.600 lol. 572 cubes now. here is some pics of the car
*new set-up 521 to 562* CAR
*new set-up 521 to 562* CAR2
*new set-up 521 to 562* SHIFTER
badsnake306
Post  badsnake306 December 28th 2010, 9:36 am
well my pistons should be here in two weeks. i just was wondering if a 4.600 bore was too big for my old school A429 heads. But here are some pics of my pushrods and rockers Twisted Evil
*new set-up 521 to 562* Jesel1
*new set-up 521 to 562* Jesel2
badsnake306
Post  bruno December 28th 2010, 10:12 am
do you have a pic of the imperfection ??? might just be a standard deal
Post  Curt December 28th 2010, 11:51 am
*new set-up 521 to 562* Waveandpointdown
Post  badsnake306 December 28th 2010, 12:05 pm
bruno wrote:do you have a pic of the imperfection ??? might just be a standard deal
yeah if you look at the first pic of the block, on the second main web you can see where its a machined surface then there is a small dark spot. it seems like when the block came out of the casting mold it took some material but there is no cracks. its about the size of a quarter and about 1/16 deep. i guess im just overly picky about stuff i spend over two grand on lol i expect it to be perfect.
badsnake306
Post  badsnake306 December 29th 2010, 1:26 pm
few more pics of the parts im using
1150 hp dominator
*new set-up 521 to 562* Dominator
billet fab two-piece pan
*new set-up 521 to 562* Oilpan1
single stage external pump
*new set-up 521 to 562* Oilpump1
badsnake306
Post  badsnake306 January 4th 2011, 11:46 am
A2000
*new set-up 521 to 562* FUELPUMP
VICTOR 4500
*new set-up 521 to 562* INTAKE
MSD DIGITAL 7
*new set-up 521 to 562* MSD
POWERGLIDE
*new set-up 521 to 562* POWERGLIDE
badsnake306
Post  138 January 6th 2011, 10:55 pm
cool build. that imperfection is just a low spot in the casting...
138
Post  badsnake306 January 17th 2011, 10:18 am
some pics of the good ol A429s
*new set-up 521 to 562* Heads1
*new set-up 521 to 562* Heads2
*new set-up 521 to 562* Heads3
badsnake306
Post  badsnake306 January 29th 2011, 11:20 am
got some presents this week. took some pics before i sent them to calico.
*new set-up 521 to 562* Piston4
*new set-up 521 to 562* Piston3
*new set-up 521 to 562* Piston2
*new set-up 521 to 562* Piston1
badsnake306
Post  badsnake306 January 29th 2011, 11:22 am
also got the hellfire ring package and trend tool steel wrist pins
badsnake306
*new set-up 521 to 562* Empty external oil pump
Post  1cobra2 January 30th 2011, 7:18 pm
Hi Ed Johnson here-
We Run a 547 -kaase p-51 with an external oil pump-have had an ongoing problem with loss of oil preasure after the run-would like to talk to you -541-549-9905 Oregon
1cobra2
Post  bruno January 30th 2011, 7:50 pm
very nice ...looks like you gained some cubic inches Twisted Evil
Post  badsnake306 February 2nd 2011, 12:07 pm
bruno wrote:very nice ...looks like you gained some cubic inches Twisted Evil
Yes i did. im hoping to make 900 hp. im having kaase redo the heads and come up with a camshaft for me. i wonder how much flow i can get out of those old school A429 heads.
badsnake306
Post  68galaxie February 19th 2011, 6:19 pm
T&D shaft rocker arms? or Jesel?
Nice stuff.
A429 heads can be modded to perform very well. Not sure if 900 HP capable.
My A429's were done in 1996. Still have these heads on my 502" Certainly not a maximum effort, didnt flow them over .700" sadly.
Intake (lift / flow @28")
.200 / 152 cfm
.300 / 237
.400 / 293
.500 / 325
.600 / 358
.700 / 376
Exh (lift / flow @28" no pipe)
.200 / 117 cfm
.300 / 161
.400 / 200
.500 / 224
.600 / 245
.700 / 258
68galaxie
68galaxie
Post  Tennessee Bullitt February 28th 2011, 10:13 am
Cool build, reminds me of the '67 mustang that came with one of my summit catalogs. It was a 572 with SCJ heads.
Tennessee Bullitt
Tennessee Bullitt
Post  badsnake306 March 24th 2011, 2:52 pm
well i sold my old a429's, intake, carb, and A460 block. and picked up C-heads, T&D rockers, Ross gas ported pistons, GRP aluminum rods and in a few weeks im picking up a eliminator premier block. My final combo is going to be 632 cubes. i wanna make 1100hp hopefully i will be able to.
badsnake306
