*new set-up 521 to 562*
+6
138
Mark Laczo
badsnake306
10 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: *new set-up 521 to 562*
well its been a while since i have updated my build thread. since i bought the C-heads used i sent them to Kaase to completly go thru them and flow test them. They should be returning to me shortly. So all i need now is a block and 4.75 crank to really get this engine built. i have a problem with picking what block to use. Either the premier eliminator block or a A460 block. i already had a A460 block and i sold it because im building a 632 w/ nitrous and i was told the A460 wasnt stout enough for that cubic inch with nitrous. but then someone told be the cylinder length in a A460 is longer than the eliminator block is this tru because if it is i think the longer cylinder would be better for the 4.75 stroke. help me out
matt
matt
badsnake306- Posts : 131
Well Kaase just called and my heads are on there way back. Ill post pics and the flow numbers as soon as i get the sheet. He told me that they flowed a little over 470cfm on the intake and 350cfm on the exhaust. flow numbers are kinda low but they told me it was because im running a 2.40 intake valve and not a 2.45. They also said that a A460 block was plenty strong for my combo.
Updates???
70FB- BBF CONTRIBUTOR
Page 2 of 2 • 1, 2
Page 2 of 2
