429/460 HEADS SCJ CJ DOVE A,C
429/460 HEADS SCJ CJ DOVE A,C Empty 429/460 HEADS SCJ CJ DOVE A,C
Post  GRANTORINO_76 November 23rd 2010, 1:07 am
Hi everyone,
My name is Leonardo i have a gran torino 76 that came with a 400 cid, now i put a used engine Marquis IV 74 460 cid, new intake, 4160 750 carb, hookers headers, 9" rear 3.50 31 spline posi nodular. I am going to upgrade in order to get more power. My question is about the heads I found a couple of new aluminum heads, but at the same time i know there is a lot 70-71 SCJ, CJ DOVE A,C so if someone can help me about which of these heads can fit my engine becuase the aluminum are goods but 70-71 i do not know, but the big question is if i can put in my 460 any of them 429 SCJ CJ DOVE A,C or the aluminum, I am not a racer guy but I want to feel some power.
GRANTORINO_76
429/460 HEADS SCJ CJ DOVE A,C Empty Re: 429/460 HEADS SCJ CJ DOVE A,C
Post  Paul Kane November 23rd 2010, 1:37 am
A 1976 Gran Torino into which you installed a bone stock 1974 460 longblock, eh? I'd say that a ported set of early style passenger car heads (C8VE, C9VE, D0VE -- we call them "early style" because they're all essentially the same) is your best bet for raising compression and increasing power for a given amount of money spent.
Swap out the D3VE's for early-style heads and your compresion will jump from about 7.7:1 to around 9.1:1.
Beware that D3VE's use a different valve train that is not directly swappable to the early-style heads, and so you will need an aftermarket roller rocker valve train for the head swap (this is also true with any of the aluminum head choices).
Paul
Post  res0rli9 November 23rd 2010, 4:35 am
Paul what CCs are the Doves stock?
Post  dfree383 November 23rd 2010, 8:33 am
in the 76cc range +/-
Post  GRANTORINO_76 November 23rd 2010, 11:58 pm
Paul,
Thank you for your answer but let me get this right. When I got the engine there was a tag telling just use 91 octane but I saw the 7.7:1 compression this number is the compression of my engine now ? cuase the guy told it was 9.5:1.due the 91 octane requiered. what do you think. Anyway I am going to open the engine in order to find out the rigth compresion. if it is less than 9.5:1 i will get 10.0:1. The engine came with 75000 miles.
Leonardo
GRANTORINO_76
Post  69F100 November 24th 2010, 4:35 pm
Leonardo I have a late model block the d9 it is a stock short block with a comp xe274h cam,the g429 intake lem sales,850 dp holley,amd a set of dove-c heads shaved .030 with home port work and cleaned up the bowls alittle it has ran the best so far 7.81@88.70 mph in the 1/8 with the wt around 3200 lbs on 93 oct pump gas and still has little more in it.
Jim
