Pistons for A. Heads?
Pistons for A. Heads? Empty Pistons for A. Heads?
Post  77 Ford Mudder August 28th 2009, 8:05 pm
Can anyone tell me if these pistons are for A. Heads?
Pistons for A. Heads? 65vh3n
Pistons for A. Heads? Xc5ax3
Any help is much appreaciated.
77 Ford Mudder
Pistons for A. Heads? Empty Re: Pistons for A. Heads?
Post  bruno August 29th 2009, 6:49 am
they look like a standard oem valve layout to me ........
here is a pic of my old weisco piston that had an extra flycut done to the because of the large cam
Pistons for A. Heads? 010-1-1
and then here is the pic of my new piston for my cj edelbrock
Pistons for A. Heads? DSCF2287
http://WWW.CKRME.COM
Post  DanH August 29th 2009, 9:18 am
that double cut looks like one is for the oem , then cut for A460 or P51 . not for a bigger cam or valve
DanH
Post  bruno August 29th 2009, 9:41 am
DanH wrote:that double cut looks like one is for the oem , then cut for A460 or P51 . not for a bigger cam or valve
i dont know Dan but on the invoice for the machine shop they had to do the cut due to the block being deck and clearance for the cam .............. who knows ...that was on the old 521
Post  DanH August 29th 2009, 10:19 am
unless you had a head that WASN'T Edelbrock or OEM, that shop took you for a good ride
DanH
Post  bruno August 29th 2009, 10:25 am
yep they were the same edelbrocks i have on the new motor
