F150 5x5.5 to 5x4.5 wheel conversion
mudtrucker
mudranger
jones
F150 5x5.5 to 5x4.5 wheel conversion Empty F150 5x5.5 to 5x4.5 wheel conversion
Post  jones November 29th 2010, 5:30 pm
Just thought I would post this information.
I was complaing about the 5 on 5.5 bolt pattern on my 93 model F150 has and a local friend informed me how to change out to 5 on 4.5.
When you go to the autoparts store just ask for a 1980-82 model F100, under 4,600lb model. Some stores have it under the small 6 cylinders and some ask for the gross weight. (Meassure just incase) They will use the same bearings and seals as the larger bolt pattern.
I am going to find out this afternoon if the hub diameter will fit the standard 5 on 4.5 wheels and take some pictures.
jones
F150 5x5.5 to 5x4.5 wheel conversion Empty 5x5.5 to 5x4.5 conversion
Post  mudranger November 29th 2010, 6:08 pm
Thats just what i wanted to hear. Thanks josh.
mudranger
mudranger
F150 5x5.5 to 5x4.5 wheel conversion Empty Re: F150 5x5.5 to 5x4.5 wheel conversion
Post  mudtrucker November 29th 2010, 7:23 pm
You are saying to buy new axles for the 80-82 truck? what about the front rotors?
mudtrucker
mudtrucker
Post  jones November 29th 2010, 8:58 pm
mudtrucker wrote:You are saying to buy new axles for the 80-82 truck? what about the front rotors?
No, I am talking about the front rotors on a 2wd. Not 100% on a 4wd.
jones
Post  f250mike November 29th 2010, 9:19 pm
I scrapped out the front from my 82 f100 before I decided to go back to 2wd Sad .
My neighbor ended up with the wheels on his 90 ranger. He wanted to switch to 15" wheels.
The 5x4.5 axles out of the 9" are still out in the garage. The housing is under my truck with moser axles now.
Josh let us know if the f100 hub fits on the f150 spindles. I may have to change mine so I can get some cheap skinnys.
mike
f250mike
f250mike
Post  jones November 30th 2010, 12:31 am
I haven't packed the bearings and torqued the rotors down yet because I don't have a set of wheels with 5 on 4.5 yet, so it might be a while before I get it completely done. All the bearings and seal off the F150 dry fit perfect in the F100 rotors though.
jones
Post  61coon December 12th 2010, 10:02 pm
Good info Jonesey.Thanks
61coon
61coon
Post  lghting94 December 12th 2010, 10:35 pm
Yes they are a direct swap!
lghting94
lghting94
Post  jones April 18th 2011, 8:30 am
sold..
jones
Post  HorsinAround February 27th 2012, 11:14 pm
Does anyone have more information on this conversion? I did as suggested above for my 95 F150 2wd and the conversion isn't a direct bolt on. The Hub/rotor assembly from the 95 is almost an inch longer than the 80-83 assembly and the outside bearing to outside bearing measurement is about .400 longer on the 95. Am I missing something?
http://www.frontpagefab.com
Post  f250mike March 14th 2012, 5:41 pm
Wish I could help but never tried the swap.
I'm curious of the differences myself now!
My 2wd front is from a 1989 f150. Alway thought (not confirmed) 80-96 were the same.
Alan can you post up the outside-outside bearing measurements for both?
Spindle dimensions from the 95 also if possible.
I'll try to tear down my 89 hub this weekend and we can compare notes.
Wish I had a 80-83 spindle to measure.
mike
f250mike
f250mike
Post  HorsinAround March 14th 2012, 8:57 pm
f250mike wrote:Wish I could help but never tried the swap.
mike
They are the same Mike, since the earlier post said the hub/rotor was a bolt on, I purchased them from the 80-83 F100 under 4600 and they were a 5x4.5. Problem is for those to work you would also need the spindle assembly from the same year which is not readily available. Because of the dimensional differences, I ended up taking those back and buying new hubs/rotors for the 95, then we put them in a lathe to turn down the step (the 5x5.5 wheels have a bigger center hole), then located and drilled the 5x4.5 bolt pattern. After that, you have to turn the hubs over and use an end mill to counter sink a larger hole for the stud heads. Not a big deal if you have the equipment or have friends that have the equipment Very Happy
Post  f250mike March 14th 2012, 10:23 pm
Thanks Allen!
I may do the same as you and redrill what I have. The machining isn't a problem at all for me.
Now I need to save up for wheels and tires.
f250mike
f250mike
Post  HorsinAround March 14th 2012, 10:27 pm
I'm with ya Mike lol. I did find some nice summit racing brand wheels at some real nice prices, but I am a long way away from that. Right now I am trying to gather the parts for the motor. All I am lacking right now is pistons, bearings, distributor, oil pan and intake.
Post  jones May 17th 2012, 8:12 am
The information I posted was for a two wheel drive only, no clue about the four wheel drives. Worked great on my two wheel drive.
jones
