2000hp engine build
jones
2000hp engine build
I have nothing else to talk about on my build so let us look down the road and do a little day dreaming. You have to stay with a 10.3 deck block and race gas.
I have always liked the old school root style blowers being that you don't have to get into electronic fuel injection and crazy exhaust work. What would it take to make 2,000hp with a root style blower, cubic inches, engine life, can you use an automatic transmission, rotating assembly requirments?
jones- Posts : 2230
Re: 2000hp engine build
Turbo Charged Merlin V12............ or a Turbine.......
dfree383 wrote:Turbo Charged Merlin V12............ or a Turbine.......
That's a little on the large size. I was thinking of sticking with a V8, 4.9 BS, 10.30 DH, 385 series Ford based, iron block.
jones- Posts : 2230
jones wrote:dfree383 wrote:Turbo Charged Merlin V12............ or a Turbine.......
you said Reliable !!!! It don't get more reliable than that @ 2000hp !!!
stick 4-500hp pump gas street motors in it....................
How about a 3516 Caterpillar? Tons of torque all day long...
jbozzelle- Posts : 3705
When I was a Kid, the guy down at the corner Gulf station put a Navy Surplus ALLISON 1310-V12 engine in to a 54 Plymouth, moved the firewall and dash to the back seat and drove it around.
Later he raced a few exhibition motorcycles at the drag strips ... his name was E.J. Potter and he did some "out of the box" stuff.
rmcomprandy wrote:When I was a Kid, the guy down at the corner Gulf station put a Navy Surplus ALLISON 1310-V12 engine in to a 54 Plymouth, moved the firewall and dash to the back seat and drove it around.
http://www.eaa1310.org/cpg144/displayimage.php?pid=920
dfree383 wrote:rmcomprandy wrote:When I was a Kid, the guy down at the corner Gulf station put a Navy Surplus ALLISON 1310-V12 engine in to a 54 Plymouth, moved the firewall and dash to the back seat and drove it around.
Ok I must admit, that is a cool looking engine.
I debated on using the word dependable or easiest. Some how I had a feeling this is the type of replies the post would garner.
jones- Posts : 2230
it gets better......
http://www.oldstox.com/images/Allison%20V-24.jpg
But still,,,,,,,,, even with the allison, only about 1200hp, but, dependable 1200hp!
Curt- Posts : 2791
Curt wrote:But still,,,,,,,,, even with the allison, only about 1200hp, but, dependable 1200hp!
The Turbo and supercharged ones are way more than 1200......
"Allison continuously improved the engine during the war. The initial rating of 1,000 hp (750 kW) was increased in stages to where the final V-1710-143/145(G6R/L) was rated for 2,300 hp (1,700 kW). By 1944, the War Emergency Power rating on the P-38L was 1,600 hp (1,200 kW).
The most powerful factory variant was the V-1710-127, designed to produce 2,900 hp (2,200 kW) at low altitude and 1,550 hp (1,160 kW) at 29,000 feet (8,800 m). This engine was static tested at 2,800 hp (2,100 kW) and was planned for installation in an XP-63H aircraft. The end of the war ended this development, so this promising experiment never flew. The extra power of this version was derived from using exhaust turbines, not to drive a turbosupercharger, but to return that energy to turning the crankshaft. This was called a "turbo-compound" "
These numbers are conservitive "Long Service numbers" the Boat and Tractor guys exceed the number by a big margin !!! Fun, Fun, Fun.... Only problem is they are getting scarce and expensive now days, being out of production for 60+ years.....
I don't think that will fit the rules or be a winning combo in drag racing. Amazing the way I created a post that after one post went so far off topic.
jones- Posts : 2230
» engine build ?
» Help with a 460 EFI engine build.
» Hey y'all! Got some engine build q's
» Help me build my engine!
» engine build ?
