Chamber softening
+12
studly
LivermoreDave
DaveMcLain
jones
138
16 posters
Chamber softening - Page 2 Empty Re: Chamber softening
Post  138 December 6th 2010, 10:29 pm
whats the advantage of going with the shorter stroke?...and thanks for the info much appreciated.
138
Post  Lem Evans December 6th 2010, 10:30 pm
Spherical dish would be cool if the package would allow it.
Post  studly December 6th 2010, 11:00 pm
shorter stroke gives a better rod ratio keep this piston in the bore fully supported and gives lots of options for Ring Packs on the pistons, that is my way of thinking plus gives the heads room to breath with big bore
studly
studly
Post  138 December 6th 2010, 11:21 pm
thanks for the info guys...
138
Post  bruno December 9th 2010, 10:08 am
here are some more pics ....these are Mike Panetta's heads from Diamond Racing Pistons
Chamber softening - Page 2 Chamber2
Chamber softening - Page 2 Chamber1
http://WWW.CKRME.COM
Post  bruno December 9th 2010, 10:10 am
Lem Evans wrote:Spherical dish would be cool if the package would allow it.
you would think it would be better from a price stand point to do the pistons and not the heads ........
Post  studly December 9th 2010, 10:42 am
I would think so to. but some heads are just too fast with small chambers and tight valve angles. I think the BBF is a great Nitrous Head design unless you are spraying major amounts on N20 I do not think much work would have to be done. I have a set of Victor GV2's being done right now and even with custom Diamond pistons i am still having the chamber softening done. but it will see lots of N20 Probbaly use a 250 hit just to start the motor Smile
studly
studly
Post  bruno December 9th 2010, 11:14 am
studly wrote:I would think so to. but some heads are just too fast with small chambers and tight valve angles. I think the BBF is a great Nitrous Head design unless you are spraying major amounts on N20 I do not think much work would have to be done. I have a set of Victor GV2's being done right now and even with custom Diamond pistons i am still having the chamber softening done. but it will see lots of N20 Probbaly use a 250 hit just to start the motor Smile
that was my point on this thread ..... does the bbf head really need this done for a 250-750hp shot ? it seems most of these guys are running sbf or sbc .... i know guys like sammy with his deal said he benefited from it ....
Post  138 December 9th 2010, 11:57 am
x2...
138
Post  dfree383 December 9th 2010, 12:07 pm
I suppose the dependes on what head your running.
Post  bruno December 9th 2010, 12:22 pm
dfree383 wrote:I suppose the dependes on what head your running.
elaborate EMC master
Post  138 December 9th 2010, 12:26 pm
TFS A460 18 bolt, non cnc, 91cc, 18 bolt... and on a side note why does the cnc'd version have a reduced chamber volume of 85cc
138
Post  dfree383 December 9th 2010, 12:34 pm
It all depends on the efficiency of the chamber and ports, from my understanding of sofening is just a method of getting motion in the desired way from the charge or in other words getting everything mixed even and properly for the application.
I would also be inclined to believe it is not a fix all or magic bullet. alot will depende on the origional chamber shape, how the heads are ported, position of the plug, valve angles and location ect.
Post  c.evans December 9th 2010, 10:49 pm
138 wrote:TFS A460 18 bolt, non cnc, 91cc, 18 bolt... and on a side note why does the cnc'd version have a reduced chamber volume of 85cc
1. To the best of my knowledge, the TFS A-460 10 bolt heads are the 91 cc heads with a cast chamber.
2. Lem and I had a little influence on the design of the 18 bolt heads and they have 83 cc chambers as cast, not 91.
3. Now then the newest TFS A-460 -18 bolt heads with the CNC chamber start out with what we call the "X" chamber which is smaller as cast, but was dedicated for being CNC'ed so you get 100% clean-up. In other words, it was meant to be CNC ported from day one. Thus the 85 cc chamber.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  138 December 9th 2010, 10:53 pm
thanks for clearing that up for me charlie...
138
Post  studly December 14th 2010, 11:47 am
Hope this helps,
What valve ange are the A460 HEADS?
18, 16?????
Charlie
studly
studly
Post  bruno August 25th 2011, 1:51 pm
so im leaning towards the TFS -A460 heads , will they benefit from this technique ?
Post  138 August 25th 2011, 2:24 pm
bruno wrote:so im leaning towards the TFS -A460 heads , will they benefit from this technique ?
why?... A vs. C...less flow, heavier piston, and not designed for shafts....but my question still goes unanswered as to which head is better suited for a large amount of nitrous.
138
Post  dfree383 August 25th 2011, 2:49 pm
The CNC A460 is better out of the box...... But the C head is designed to be Custom Modified to the application so...............
Post  138 August 25th 2011, 2:59 pm
dfree383 wrote:The CNC A460 is better out of the box...... But the C head is designed to be Custom Modified to the application so...............
seems to me where the A deal pays of is when you get them out of the box and ready to run... and thats with ss valves and so so springs. but for brunos deal hes gonna want ti valves and a bigger ex. valve...so there goes the "deal"... but to each their own... to be honest I hope he does go with the A's because I wanna see what they can do, with stud rockers, fully ported, small cid. large does of n2o, and a smallish cam, and all set up for low maintenance and reliability..because thats exactly what I'm doing for round 1.
138
Post  dfree383 August 25th 2011, 3:02 pm
Phillip Oakley's motors are a good example of that A460's can do.......
But in Brunos case he already has the C460 stuff........ Run what you got.
Post  bruno August 25th 2011, 9:34 pm
dfree383 wrote:Phillip Oakley's motors are a good example of that A460's can do.......
thats fine Dave but i want a max build Wink
Post  138 August 25th 2011, 9:45 pm
well then those C's are the closest thing your gonna get to a Thor, unless you have increased your 16000 engine budget to just a head budget,lol...so whats the hang up? I'm really curious as to why you are set on those A's
138
Post  dfree383 August 26th 2011, 7:23 am
C460's then......... or Get alot more MONEYand step up to Profilers, Thors or Hemi Heads and 800"s........
Remember "Max Effort" and "Budget" do not belong in the same sentence.
Post  QtrWarrior August 26th 2011, 7:44 am
dfree383 wrote:C460's then......... or Get alot more MONEYand step up to Profilers, Thors or Hemi Heads and 800"s........
X2...If you're on a budget, how is it max effort ??
QtrWarrior
QtrWarrior
