Main caps..
+8
lance flake
bb429power
FORDMUD
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Main caps..
Are the main caps different for the different casting numbers. This a 2 bolt d0ve-a. Also, if I find some caps from the same style block will they most likely need an align bore and hone? Ideally I would like to just hone.
FORDMUD- Posts : 290
Re: Main caps..
get some 4bolt caps while your at it.you'll be glad you did.
Re: Main caps..
If they are not the caps that came on it they will need lign bore and honed I would not try to run it with out having it aligned
Last edited by 69F100 on December 12th 2010, 9:55 pm; edited 1 time in total (Reason for editing : hit wrong thing)
Re: Main caps..
69F100 wrote:If they are not the caps that came on it they will need lign bore and honed I would not try to run it with out having it aligned
Re: Main caps..
I think you meant to edit you've got two different answers now, what is it!!!69F100 wrote:69F100 wrote:If they are not the caps that came on it they will need lign bore and honed I would not try to run it with out having it aligned
bb429power- Posts : 3129
Re: Main caps..
I planned to stay two bolt if it would work with just a hone. If it needs bored and honed, might as well do the 4 bolt. I need to find front and rear caps either way, and those billet ones are expensive.
Re: Main caps..
Keep the caps that came with the block and correct [if needed] with a hone i.m.o.
If you change to 4 bolt caps the story will change.
Re: Main caps..
yes i hit the wrong spot
I would not try to run it with just honing I tried that years back on a 302 with so bad results
Re: Main caps..
Lem Evans wrote:Keep the caps that came with the block and correct [if needed] with a hone i.m.o.
I bought the block without any caps. I know what you guys are thinking, And I feel pretty stupid, but I just totally missed them. I guess I was busy checking the rest of the stuff, but anyway seller now says the are lost. And I'm looking for some.
Re: Main caps..
Save the Dove A block for later when you step up and put the after market caps on it. For now just get another stock block the are plentiful and cheap.
Re: Main caps..
I know how that is the 302 I did for my exbother inlaw was missing one main cap he couldn't find so we got one off another engine and honed it good the crank lasted about 100 miles and spun that main bearing.That the reason I say you need to have it aligned
Re: Main caps..
eliminator has all 5 caps in the set,435 for cast,455 for steel.some have said the cat or procomp caps work fine,the machine work is the most important thing.
Re: Main caps..
What are the options for aftermarket front and rear caps? Or should I run factory front and rear with the center billets. I'm going to build this one right the first time. Forged 4.14 eagle crank, h-beams. Building a pump gas iron head engine to run at or above 7k.
Re: Main caps..
Does cat have front and rear caps? May look into eliminators.
Last edited by FORDMUD on December 12th 2010, 10:23 pm; edited 1 time in total (Reason for editing : Realized it was only 20 more for the steel.)
Re: Main caps..
i dont know about the cat's but look here,http://www.eliminatorproducts.com/FORDMUD wrote:Does cat have front and rear caps? May look into eliminators.
Re: Main caps..
I'll look through my stuff, I think I have the center three caps off of a DOVE block if it would help.
Nevs- BBF CONTRIBUTOR
Re: Main caps..
That would be a start. I'm hoping to find some from a block that blew up or something.
Re: Main caps..
i may have a torn up block with some caps. i know i got 3 center caps from a splayed conversion. if we can't find anything to work i know i got a pile of blocks to choose from. i seen where i missed your call yesterday. if you get a chance ring me up tomorrow.
lance flake- Posts : 142
i have some
i have all 5 off a block that had a crack in it. you can have them just pay the shipping. im in redford mi. thanks jim
new2460- Posts : 195
Re: Main caps..
If you want to go 4 bolt I have a boss 429 front 4 bolt main
AK- Posts : 67
Re: Main caps..
Whats the usual time frame before you out a bad seller? I'm almost certain this guy has no intentions of making this right.
Re: Main caps..
I ussually give them until the deadline they set or until I cant make any promising contact with them. Nothing pisses me off more than when someone screws with my time or money.
Aaron
Aaron
AK- Posts : 67
Re: Main caps..
what's the problem? who done what?FORDMUD wrote:Whats the usual time frame before you out a bad seller? I'm almost certain this guy has no intentions of making this right.
Re: Main caps..
I have never seen him post here. I really doubt it will hurt him for folks to know his ways. I'm giving him till tomorrow to email. text, or call me back. I'm partly to blame here, I bought some parts that turned out to be junk. I was going on his word. I like to think all people are like me. If I tell you something you can believe it. This wasn't the case with him..
Page 1 of 2 • 1, 2
» Alum Block Question
» 4 Bolt caps
» WTB OEM 460 Main Caps
» Billet Steel 4 bolt main caps for sale SOLD
» 4bolt main caps
» 4 Bolt caps
» 4bolt main caps
Page 1 of 2
