what pistons to use?
what pistons to use? Empty what pistons to use?
Post  bigunitmudracing December 14th 2010, 12:15 am
what pistons do i need to get flat top zero deck for my 69 460?? want forged ... please help , was looking at seal power and there web site sucks a** ...
thanks
bigunitmudracing
bigunitmudracing
what pistons to use? Empty Re: what pistons to use?
Post  DanH December 14th 2010, 5:57 pm
looking for a drop in piston ? no block machening ? custom piston and you must give the specs
DanH
Post  bb429power December 14th 2010, 6:05 pm
1/2 stroke + rod length + compression height =stack height. Since the deck is 10.3 then you want the stack height to add up to 10.3 since you want it at zero deck.
If its stock then 1/2 stroke = 1.925 + rods (6.605) = 8.53..........(Deck height) 10.3 - 8.53 = 1.77. You with me here? Your pistons need to have a 1.77 compression height assuming it has never been decked, and is a stock stroke 460 in order for the piston to be at zero deck without machining.
Thumbs up? Wink Or down? No
There's Diamond pistons, they are forged.
bb429power
bb429power
Post  schmitty December 14th 2010, 8:30 pm
Probe and Diamond have some good pistons. Cool Make sure and attach them to the crank with a good set of rods. Cool
Post  cool40 December 14th 2010, 10:34 pm
i think a 69 block is 10.295. Question
Post  bb429power December 14th 2010, 10:45 pm
cool40 wrote:i think a 69 block is 10.295. Question
DOH!!! Mad 1.72 compression height Smile
bb429power
bb429power
Post  cool40 December 14th 2010, 11:00 pm
whatever you use,drop one in and see what it "is"before you cut the block or you may need to cut your new pistons.dont ask how i know that! Embarassed
