557 question???
+7
studly
AK
Mark Laczo
1Bad91
11 posters
Page 1 of 3
Page 1 of 3 • 1, 2, 3
557 question???
What mods need to be done to make a stock block a 557? I here several different opinions about this. I thought the block is good to this size without mods. Is this true??
1Bad91- Posts : 267
Re: 557 question???
If you have a block that will bore to 4.440" and add a 4.5" crank you will have the 557".
Gennerally you'll need to deck the block and check the align hone of the main bores.
Re: 557 question???
Nothing special for the stroker, just the typical stuff you should do on a build anyway..............
557"
X2 what Lem said,
For my frame of mind and to find out how many more bores/hones the block may have left in it I got my block sonic checked, then did a half full cement job, added 4-bolt mains and good to go for some HP & RPM's.
FWIW Mark
FWIW Mark
Mark Laczo- Posts : 274
Re: 557 question???
I have a set of headers that were built for my car. They fit my cast heads but are definitely over sized. I did this on purpose because the future heads I wanted to use....either A460 or P51. Can I get adapters or will my headers not work with these heads??
1Bad91- Posts : 267
Re: 557 question???
I really would want to stay with the stock block because of weight savings. I know many would think this is dumb but I feel a stock block can handle some serious power if built right. The A460 block is about 100# heavier if I'm not mistaken?
1Bad91- Posts : 267
Re: 557 question???
P51 heads will work with your headers as long as yours are the scj size, A460 heads your getting new headers lol. I'd go with an A460 block and make it a big bore to get some weight out of it.........I'd rather pay the price for the addition weight and have the better block anyway.
Re: 557 question???
richter69 wrote:P51 heads will work with your headers as long as yours are the scj size, A460 heads your getting new headers lol. I'd go with an A460 block and make it a big bore to get some weight out of it.........I'd rather pay the price for the addition weight and have the better block anyway.
Why couldn't A460 work? Couldn't I get adapters made or are the ports completely way off??
1Bad91- Posts : 267
Re: 557 question???
they just aint gonna fit.............what size headers do you have now?
Re: 557 question???
No sir they are not 100# heavy. I posted a deal the other day show the 32#s Jetboat Bob bored out of an A460 block. It will be heavier but they can be so much bigger1Bad91 wrote:I really would want to stay with the stock block because of weight savings. I know many would think this is dumb but I feel a stock block can handle some serious power if built right. The A460 block is about 100# heavier if I'm not mistaken?
Re: 557 question???
besides the little bit of extra # will help keep the front end down................
Re: 557 question???
richter69 wrote:they just aint gonna fit.............what size headers do you have now?
2 1/8 to 3.5 inch
1Bad91- Posts : 267
Re: 557 question???
4.56 bore X 4.3 stroke P51 deals seem to work pretty good...............
Re: 557 question???
richter69 wrote:4.56 bore X 4.3 stroke P51 deals seem to work pretty good...............
Define "pretty good"?
1Bad91- Posts : 267
Re: 557 question???
lets just say you wont need a silly blue bottle and you'll be more worried about tires and suspension rather than header size and block weight.............
Re: 557 question???
I would think a 4.5 stroke would be a better deal with that much bore. I'm getting the impression of a short stroke big bore deal?? This the idea?? What size motor is this anyway?
1Bad91- Posts : 267
Re: 557 question???
piston speed, swept volume........I dont know........how much power do you need?
Re: 557 question???
I would like to make around 850hp and SOME on motor. I still planning to keep the bottle in the car too...
1Bad91- Posts : 267
Re: 557 question???
i dont mind going with a A460 block either. Def smarter
1Bad91- Posts : 267
557"
How about 846hp ?? LOL.
I think a filled DOVE block @ 4.44" weighs very close to an unfilled A460 that is bored to 4.56+ or larger. I guess alot of it will depend on your budget and/or who your builder is and what is charged. The A460 will obviously let you grow for future builds.
JMO Mark
JMO Mark
Re: 557 question???
I recently read in hotrod or popular hotrodding or one of those mags about a kaase stroker build where he was going to use a 4.5 arm then after mockup switched to a 4.3 because he felt the pistons were pulling too far out of the bores. Anyone had this experience with an early block?
AK- Posts : 67
Re: 557 question???
found it
"Look closely and you'll notice that our first-choice 4.500-stroke Scat crank pulled virtually the entire piston skirt out of the bottom of the cylinder sleeve. This obviously was not going to work, and since we already had the pistons, we elected to move down to a 4.300-inch-stroke Scat crank and 0.100-inch-longer rods."
http://www.carcraft.com/techarticles/ccrp_1009_834hp_429_boss_ford_engine_build/index.html
AK- Posts : 67
Re: 557 question???
INteresting article. I had talked to a few people about Kasse builds. He sure knows what the hell he is doing
1Bad91- Posts : 267
Re: 557 question???
The pulling the piston out of the bottom of the cyl aint no big deal.
Re: 557 question???
Just makes me wonder if it wasnt good enough for him, then what about the rest of us???
AK- Posts : 67
» Cam question?
» SBF question ?
» Everybody watch this
» E85 question.....
» Cam question?
» SBF question ?
» E85 question.....
Page 1 of 3
