Mezier water pumps
powerstrokeace
Moodyblues
Mezier water pumps
I have a meziere water pump that has been on my car for about 4 yrs now. Is there maintenance that needs to be done to these pumps? Mine seems to not be turning as fast as in the past, might just be me...........
Your thoughts?
Your thoughts?
Re: Mezier water pumps
Battery up to snuff? I've had one for 10 years and never a problem
Ace
Ace
powerstrokeace- Posts : 1496
Mine is still going strong after 10 yrs. also.
342g- BBF CONTRIBUTOR
Just me then, noticed my water temp going and it doesnt sound like pump is turning as strong. As a matter of fact in the fall had to change the electrical connection. Battery not a issue.
THanks
THanks
Moodyblues wrote:Just me then, noticed my water temp going and it doesnt sound like pump is turning as strong. As a matter of fact in the fall had to change the electrical connection. Battery not a issue.
THanks
Do you use any kind of llube?, I run a little anti all year round.
How many amps is it pulling?
Harold, the pump has sealed bearings, shouldnt need any lube, and if it does,,,,,,,,,,,,,, that could be his problem.
^^^^ and, dont run antifreeze
Curt- Posts : 2791
The impeller may be loosening up causing it to bind on the side case. Had one do that a few years ago. Took it apart and tightened the nut with a little red loctite and it was as good as new. The pump was probably 5-6 years old then. Still have it and it works fine to this day.
Travis
Travis
TravisRice- BBF CONTRIBUTOR
TravisRice wrote:The impeller may be loosening up causing it to bind on the side case. Had one do that a few years ago. Took it apart and tightened the nut with a little red loctite and it was as good as new. The pump was probably 5-6 years old then. Still have it and it works fine to this day.
Travis
Thanks Travis, I'll check that.
Russ Hood
Had a friend who had his burn the windings up in the motor this year. Just quit. No idea how old it was though.
514Fox87- Posts : 436
» Water Pumps
» A couple questions on water and fuel pumps
» Moroso Billet Aluminum OEM Mount Electric Water Pumps
» Switched from mech water pump to Moroso electric water pump
» 460 Water Pump Crossover Tube that goes in the Intake to the Water Pump?
