Rod/piston assembly help.
BigDave65
I'm sure if I stared at I'd figure it out but since the parts are not at home with me I need help.
Which way do I put the rod chamfer when I assemble the rods/pistons? Won't all the chamfered sides go in the same direction since 4 will be flipped for the opposite bank?
jbozzelle- Posts : 3705
Re: Rod/piston assembly help.
The rod chamfers should go to the outside of each rod journal so you have clearance at the radius on the journal. The squared sides of each rod should go together, and the chamfers opposite each other on each journal.
So yeah, 4 will face one direction and the other bank will go the other direction.
BigDave65- Posts : 567
Yep, aaaaall 8 of 'em.Lem Evans wrote:Big chamfer toward the intake valve relief.
Thanks guys.
And the intake relief goes down, right? Figured I'd ask since there is not internet at the shop...
You're my hero!
[xxxxxxxxxxxxxxxxxxxxxxxxxx
jbozzelle wrote:You're my hero!
That sounded gay. Let me rephrase that. You're the HeRo...
It is what it is.................
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
» 3.89 9" assembly
» Stroker kit wanted
» BBF used N/A rotating assembly and cam
» rotating assembly
» 3.89 9" assembly
» rotating assembly
