514 Keith Craft BBF
514 Keith Craft BBF
I have a 514 big block motor that is in my mustang now and is running. It has around 700 miles on it right now and motor is very strong. If you put a set of p-51 heads on this motor it would be pushing a little over 700hp then. These are the parts it has in it now. I am wanting $7,000 for the motor and you would get everything from the carb. down to the pan. If you wanted my built C6 it would be anoth $1,500. If you would like to hear the motor run and come check it out you can call me at 314-504-3041 my name is Damon thanks guys by the way I am in St. Louis MO.
Keith Craft 514 short block, probe pistons, eagle rods and crank, arp bolts
D3 heads, ported and polished, with Comp springs, and guide plates
Comp hardened pushrods
Comp 1.73 roller rockers
950hp carb
610 lift 300/310 dur solid flat cam
Torker 2 intake
D&D mid length headers
Ford Motorsport valve covers
Procomp electric water pump
MSD distributor
ATI SFI Balancer
MSD Wires
950hp carb
Torker 2 intake
MSD distributor
ATI SFI Balancer
MSD Wires
thejudge69- Posts : 37
Re: 514 Keith Craft BBF
The new price is down to $6,000 and we can talk if you want me to drop it off.
This is a great motor I just need the money to do some projects. The motor runs strong and is fast in my 94 Mustang. Lets see some offers guys gotta move this motor.
I will sell the motor for $5,000 without the carb. and the electric water pump.
Come on guys is this thing not priced well? I will let the motor go from carb. to pan for $5,400 even the headers go with it.
COME ON GUYS COMPLETE MOTOR FOR $4,700 and will sell my K-member out of a 94 Stang too.
$4,500 for everything. Someone come and get this motor it is to good to pass up.
Hey judge welcome to the Auction block....
the Coug- Posts : 3055
Thanks man how are you doing tonight?
If you want to see pics of motor you can go to this link http://stlouis.craigslist.org/pts/1382994853.html
thejudge69 wrote:If you want to see pics of motor you can go to this link http://stlouis.craigslist.org/pts/1382994853.html.
Just tried it but it says page not found.
83-88T-Bird Guy- Posts : 1003
thejudge69 you gotta remove the period at the end:
Thanks Luke !
Try the link in again in my post I had do delete the period at the end.
NEW DEAL LETS MOVE THIS
I have a 514 big block motor that is in my mustang now and is running. It has around 700 miles on it right now and motor is very strong the motor is making 500hp right now and needs a bigger cam and a set of aluminum heads. I am wanting $5,800 for the motor and built C6 you would get everything from the carb down to the pan. For the price of $6,200 I will give you my griffin radiator, A1000 fuel pump and regulator, and my ignition system (Hyperfire) If you would like to hear the motor run and come check it out you can call me at 314-504-3041 my name is Damon thanks guys
950hp carb
Torker 2 intake
MSD distributor
ATI SFI Balancer
MSD Wires
950hp carb
Torker 2 intake
MSD distributor
ATI SFI Balancer
MSD Wires
» [b]514 Keith Craft BBF (Part Out)[/b]
» Blow Thur Carbs
» foxbody race craft welded style caster camber plates new
» pro comp headed 557 build in new car craft
» June 2001 Issue of Car Craft Mag
» Blow Thur Carbs
