460 rebuild questions
I have a stock 460. I have some parts I want to buy.... this is going in my 79 F150 4x4. I will bog and offroad some and drive on the street...want some good HP/TORQUE.
Does this look good so far?
COMP Cams K34-235-4 - COMP Cams Xtreme Energy 4x4 Cam and Lifter Kits
Clevite Engine Parts SH1111S - Clevite Camshaft Bearing Sets
Edelbrock 2166 - Edelbrock Performer Intake Manifolds
Sealed Power 205637M-011 - Federal Mogul Engine Re-Ring Kits
Melling M84HV - Melling High-Volume Oil Pumps
Sealed Power ZH418CP - Speed-Pro Hypereutectic Pistons
TOTAL AFTER SHIPPING $1,041.25
Need some headers...hmmm screw spending $500 on some.
Dr.Ford- Posts : 130
Re: 460 rebuild questions
Moved it for you Derek, you'll get more info here.
I wouldn't think the HV pump would be necessary.
schmitty- Posts : 4538
Lol Rob, it's Derek from GA. Whose Brent?
Dr.Ford wrote:Lol Rob, it's Derek from GA. Whose Brent?
I got a case of CRS today
The H418CP pistons have coated skirts and a .240" deep oblong dish which will only get you about 8/1 compression ratio.
You DON'T want those...!
The H582CP pistons have the same skirt but, have only a .065" deep oblong dish which will get you about 9/1 compression ratio.
There is also the H612CP pistons with the same skirt and have a .189" deep oblong dish however, those have .020" more compression height so they will be closer to the block deck and yield about 8.8/1 compression ratio. They are from the F.I. engines and use a lower tension metric ring pack.
ALL of these pistons have production diameter intake notches.
Then there is the H535CP piston which has the same skirt but, is a flat-top with the higher compression height and will get you about 9.5 compression ratio. These also have larger intake valve notches to be able to use larger intake valves than production.
Idk what kind the rest of my pistons are......they are dished like that but I dont know..
I may get this kit
http://www.summitracing.com/parts/FEM-MHP178-011/
It looks ok?
It looks ok?
call Randy up and get a complete kit with all the right stuff.
Whose Randy? What will the kit come with?
rmcomprandy is Randy Malik, real nice guy and where my engine is going to.
Dr.Ford wrote:Whose Randy? What will the kit come with?
http://www.rmcompetition.com/
» Questions on a new rebuild?
» 429 Rebuild questions
» 4160 Carb Rebuild/Cleaning Questions
» i need to rebuild my 5.0
» 521 Refresh questions
