pushrod lenth checkers
pushrod lenth checkers Empty pushrod lenth checkers
Post  bb429power January 17th 2011, 5:58 pm
About what length range should I be looking at? D1VE block (pretty sure but I can go check if needed for whatever reason), decked 5 or 10 thou (that's what the machinist said, never got an exact answer) Rolling Eyes D0VE-C's, Harland Sharps.
http://www.summitracing.com/search/Part-Type/Pushrod-Length-Checkers/Universal/Yes/?Ns=Price|Asc
bb429power
bb429power
pushrod lenth checkers Empty Re: pushrod lenth checkers
Post  bb429power January 17th 2011, 6:10 pm
And I keep going back and forth, its a 71 429 block. The deck height is 10.3 or 10.32, I keep reading its one and then its the other. I think its a 10.32 block but decked .010 making it 10.31 and my piston to deck is .015??? My freaking gosh darn! Stack height is 10.295, I think its a flab nabbit 10.32 deck height block then. scratch Pissed off at the machinist now...
bb429power
bb429power
Post  Curt January 17th 2011, 6:12 pm
You'll need something that will measure between 8 and 9" with ball ends. 8.55 is an approx "standard" lenght
Post  bb429power January 17th 2011, 7:09 pm
Okay, thanks. Now I got to figure out my gasket thickness and crap Neutral
bb429power
bb429power
Post  Lem Evans January 17th 2011, 8:11 pm
No......you just gotta get a checking rod the lenght that Curt said.
Post  bb429power January 17th 2011, 8:37 pm
Lem Evans wrote:No......you just gotta get a checking rod the lenght that Curt said.
Yeah, I still have to figure out my gasket thickness to figure out my piston to head clearance and compression. I know its a felpro kit and the head gaskets are of course for a 4.390 bore. Not sure on the thickness, I need to call them.
bb429power
bb429power
Post  Lem Evans January 17th 2011, 8:44 pm
My bad....I thought you had ask about a checking pushrod.
Post  bb429power January 17th 2011, 8:57 pm
Lem Evans wrote:My bad....I thought you had ask about a checking pushrod.
No I did initially, but the way I worded that comment made it sound like I was trying to add everything up. MY bad Laughing
bb429power
bb429power
Post  Curt January 17th 2011, 8:59 pm
I'm guessing .041 on the gasket thickness.
Post  69F100 January 17th 2011, 9:05 pm
Justin you get a cam yet I sell my cam and lifters they are already broken in,I am going to get with Lem on a new solid flat tappet for mine. Laughing
Jim
Post  bb429power January 17th 2011, 9:13 pm
69F100 wrote:Justin you get a cam yet I sell my cam and lifters they are already broken in,I am going to get with Lem on a new solid flat tappet for mine. Laughing
Jim
Soon, soon she will be ordered along with many (eh, a couple) other engine parts Twisted Evil I would but this cam is exactly what I wanted, unless you got a bigger shaft than me. Then I may consider Razz
http://www.lunatipower.com/Product.aspx?id=2287&gid=245
bb429power
bb429power
Post  69F100 January 17th 2011, 9:30 pm
Yes mine is bigger lift .562 int .565 exh give me a min I pull it up for you
http://www.summitracing.com/parts/CCA-CL34-247-4/
Post  bb429power January 17th 2011, 10:48 pm
I thought you hadn't pulled it up yet Laughing Been waiting all this time for nothing. You may have more lift and one more LSA degree, but I got more duration. What a Face Same rpm range which I never know for sure how accurate those are when they say this rpm to this rpm. Mine is supposed to sound really lopey, which is something I really wanted.
bb429power
bb429power
Post  69F100 January 17th 2011, 11:38 pm
you got more advertised duration you only have 230 at .050" on int and exh Mine has 230 int and 236 exh at .050" duration with more lift if it has any more lope than this one it will have a hell of a lope.Just me I have tried the lunati cams and I don't like them as good as comp.I have the 292 .512 lift bracket master in my 351w it don't hit near as hard as it did with 280h .512 comp cam plus perform as good as comp.
Post  Curt January 17th 2011, 11:43 pm
They don't lope at all when you're up against the converter. bom
Post  bb429power January 17th 2011, 11:52 pm
Curt wrote:They don't lope at all when you're up against the converter. bom
Yep Laughing I don't like the sound of it when it has a low stall converter in it.
But isn't it lobe overlap that mainly causes the lope?
bb429power
bb429power
Post  bb429power January 18th 2011, 12:01 am
What exactly is it that makes it have that lope other than its intended rpm range? I don't want to be the guy that's like "but the manufacturer said", BUT the cam I had/lost was supposed to give that "lopey idle that so many people love to hear".
https://s545.photobucket.com/albums/hh375/69F100/?action=view&current=RangerMotorfiredup003.mp4#!oZZ102QQcurrentZZhttp%3A%2F%2Fs545.photobucket.com%2Falbums%2Fhh375%2F69F100%2F%3Faction%3Dview%26current%3DRangerMotorfiredup008.mp4
And Jim, does the fact that your .050 duration is about the same and the adv. duration is lower mean that it is a more agressive lobe angle?
bb429power
bb429power
Post  69F100 January 18th 2011, 12:45 pm
Justin I am not sure I am still learning Lem would be better to ask.
Post  frank13 January 18th 2011, 12:47 pm
dont buy the pushrod checker. get me your address, and i will send you mine to borrow till you are done. I am done with mine for atleast a long long while.
Just send her back when you are dont with it, no rush though.
frank13
frank13
http://www.frankskinkracing.com
Post  bb429power January 18th 2011, 12:53 pm
Okay, thanks Frank. I'm sending you a message.
bb429power
bb429power
