DOVE HEADS MILLED
bigunitmudracing
DOVE HEADS MILLED  Empty DOVE HEADS MILLED
Post  bigunitmudracing January 18th 2011, 11:12 pm
anyone ever cc a set of dove heads after cutting off .100 off of them.... according to my math .. it should be around 20 cc's well if they are 75-77 and you take 20 off ,55-57????
anyone got facts??
bigunitmudracing
bigunitmudracing
DOVE HEADS MILLED  Empty Re: DOVE HEADS MILLED
Post  res0rli9 January 19th 2011, 12:50 am
wouldn't go past .050
Post  bigunitmudracing January 19th 2011, 12:54 am
y not??? need advice
bigunitmudracing
bigunitmudracing
Post  dfree383 January 19th 2011, 11:42 am
weakens the deck and sealing of the chambers.
Plus at .100 you will be well into the valve seats.
Post  bigunitmudracing January 19th 2011, 1:08 pm
anyone else???
bigunitmudracing
bigunitmudracing
Post  bb429power January 19th 2011, 4:42 pm
Not sure what it is but there is a formula as to how much to take off for each cc you want reduced. Every setup is different with the valves and what not.
bb429power
bb429power
Post  69F100 January 19th 2011, 7:46 pm
mine was shaved .030 if I am not mistaken the michine shop guy told me they are 70 or 71 ccs now I will have them off in a few weeks then i can re cc them and let you now what they are. with .030 shaved off.
Jim
Post  k.pascoe January 27th 2011, 1:00 pm
Yes you can shave up to.125. if the head can handle it. My personal DOVE's are cut that far. The intake valves on the high side will seat higher than the deck. In other words with the head assembled about .150 of the intake valves will touch a straight edge with it laying on the deck.
Of course you'll have to cut the intake side of the head or intake manifold, elongate bolt holes. But yes it can be done. And yeah it works well. Just take your time with them.
k.pascoe
Post  IDT-572 January 28th 2011, 12:01 am
My D2ve's were milled over .100 and all the valve margin was above the deck. 13:1 compression and 10 years of running the crap out of it and 175 shot of NOS on it to boot. I have never seen the deck to be a problem on a BBF 385 cast head.
With your deal being a vacuum rule deal, you need all the compression you can get. Sneak up on the piston to head clearance, Just watch the piston to valve clearance. wide lobe sep vacuum cam you may be ok.
