braided fuel line failure?
D. Sea
the1969fordguyinky
braided fuel line failure? Empty braided fuel line failure?
Post  the1969fordguyinky January 19th 2011, 4:35 pm
How does one know when braided fuel line has reached the end of it's life?
With rubber hose the cracks could be viewed or a squeeze would show it was not pliable.
My garage has a strong gas smell that I suspect is the fuel line seeping but how does one test this theory?
All of the line in the car is braided, including a return line...
Last edited by the1969fordguyinky on January 19th 2011, 4:37 pm; edited 1 time in total (Reason for editing : added some detail)
the1969fordguyinky
the1969fordguyinky
braided fuel line failure? Empty Re: braided fuel line failure?
Post  dfree383 January 19th 2011, 4:45 pm
how old are they?
Post  the1969fordguyinky January 19th 2011, 5:14 pm
5-7 years
the1969fordguyinky
the1969fordguyinky
Post  dfree383 January 19th 2011, 5:19 pm
with the chemicals in race gas, I'd guess your past the life........
Post  richter69 January 19th 2011, 5:23 pm
that old I'd change um
Post  the1969fordguyinky January 19th 2011, 5:37 pm
Now that I'm (mostly) past the look of braided line, is there any reason to use it instead of hard aluminum line? I'd still use braided around the regulator and carb. it would be a shame to waste all those fittings.
the1969fordguyinky
the1969fordguyinky
Post  dfree383 January 20th 2011, 10:28 am
I don't like the aluminum line, I'd use steel its alot tougher, but harder to work with.
Post  D. Sea January 20th 2011, 4:26 pm
Teflon innertube Braided line...
D. Sea
D. Sea
Post  jones January 20th 2011, 5:15 pm
I like aluminum, easy to bend and not near as exspensive and braided line.
jones
Post  nitro717 January 20th 2011, 5:46 pm
wow..... I have 13-14 years on mine
nitro717
nitro717
Post  Wayne Pearce January 20th 2011, 9:50 pm
The braided stainless fuel lines on my Model A lasted a long, long time (about ten years). They hadn't started leaking, but I had a couple of bouts with the Holley's flooding because of "stuff" getting stuck in the needles, and seats. It turned out that the lines were disintergating internally, and bits of the fuel line were finding their way into the carbs. Last winter, I tore out every piece of braided fuel line, and replaced them with new braided lines, I think ten years was a very good service life.
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  the1969fordguyinky January 21st 2011, 9:24 am
Mine does more street duty than it does time at the track and it only gets race gas on special occasions. The additives in regular gas probably break down rubber faster than race gas? I'll have to look into this teflon braided hose since I already have all the AN fittings for braided.
I suppose it never occurred to me that fuel line had a limited lifespan.
the1969fordguyinky
the1969fordguyinky
Post  dfree383 January 21st 2011, 9:42 am
Ethanol is tough on rubber.
Post  Wayne Pearce January 21st 2011, 4:04 pm
The teflon lined braided stainless is real nice stuff, but I think you'll find that it requires different AN fittings than the "regular braided stainless.
Wayne Pearce
Post  D. Sea January 21st 2011, 4:13 pm
Wayne Pearce wrote:The teflon lined braided stainless is real nice stuff, but I think you'll find that it requires different AN fittings than the "regular braided stainless.
Yes, totally different fittings for the teflon innertube braided lines and very expensive (as if anything for a race car isn't)... I've been using the teflon braided lines for a LONG time with no failures.
D. Sea
D. Sea
Post  Barney January 21st 2011, 4:37 pm
I use aluminum hardline everywhere except under the hood. Even my return line is aluminum hard line. Its light, inexpensive, easy to work with, and lasts forever.
Barney
Barney
