nitrous enrichment fuel cell
How much fuel do you use with one ten pound bottle of nitrous. I want to keep the enrichment tank as small as possable.
375ultra- Posts : 7
Re: nitrous enrichment fuel cell
depends on 1/8 or 1/4 and how much you are spraying
a 3 gallon tank should be plenty
studly- Posts : 512
a small 3 gallon should be fine for 1/4 mile 250hp
studly- Posts : 512
If I understand you correctly your talking about a nitrous only enrichment cell ?? If that's the case a 1 gallon cell will be fine. Your system doesn't use as much fuel as you might think just for the nitrous.. Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
I run a 1 gallon enrichment tank on a 250 shot and I get several runs before the fuel goes to the level of the foam in the cell. Then I add a quart of fuel and go another few rounds.
Greg
Greg
Greg_P- Posts : 1009
» Fox Body "Nitrous Enrichment Fuel Tank"
» Boost vs Fuel Enrichment?
» 20 Gal Fuel Safe Bladder Fuel Cell
» 5 gallon alum fuel cell with -12an fitting
» 1 gal fuel cell
» 1 gal fuel cell
