changeing rod length on 3.85 crank
138
bigunitmudracing
what is the advantage or what do u gain by useing a 6.800 instead of a 6.605 on a stock crankshaft... i understand u use different pistons...
bigunitmudracing- Posts : 159
Re: changeing rod length on 3.85 crank
lighter than the weight gained by the larger rod?
138- Posts : 1593
138 wrote:lighter than the weight gained by the larger rod?
In my experience, yes. For example, an H beam Eagle rod in the 6.605" length versus a 6.700" or 6.800" Chevy style rod is actually heavier than the longer Chevy rod. So, coupled to the piston weight savings, it is significant.
Nevs- BBF CONTRIBUTOR
longer rod can be a advantage for that must run small port heads
DanH- Posts : 1081
I run the 6.800 eagle rod with the 3.85 stroke I like the smaller rod bearing and smaller wrist pin which is also lighter.
466bronco- Posts : 23
Lighter piston
Smaller diameter rod journal
Better off putting more stroke in it.
Outlaw5.0- Posts : 122
» crank length question
» Crank snout length ??
» spacer length behind balancer on crank snout ?
» changeing my transmission
