spacer length behind balancer on crank snout ?
5pointslow
spacer length behind balancer on crank snout ? Empty spacer length behind balancer on crank snout ?
Post  5pointslow October 22nd 2015, 8:06 am
using a stock crank with Sfi romac balancer
i know i have seen some have to be machined , wasnt sure what the length needs to be
5pointslow
5pointslow
spacer length behind balancer on crank snout ? Empty Re: spacer length behind balancer on crank snout ?
Post  5pointslow October 22nd 2015, 12:10 pm
i have a steel one that was going to be used on previous build i got , for some reason i think it needed to be shortened up
5pointslow
5pointslow
Post  dfree383 October 22nd 2015, 12:21 pm
Never heard of needing to shorten one.
Post  5pointslow October 22nd 2015, 12:25 pm
dfree383 wrote:Never heard of needing to shorten one.
thats why i was wondering i thought for some reason i read on here ...could be wrong and prob am that some get shortend
i have a steel one i got from lem a few years back
5pointslow
5pointslow
Post  glenevans October 22nd 2015, 12:30 pm
The Innovators West dampner I got from Lem does use a shorter spacer, seems like .250 inch or so, but Lem would know for sure on the exact length. So maybe other brands would be the same situation.
glenevans
Post  Wheelie58 October 22nd 2015, 8:02 pm
Long OE snout with a "normal" balancer like that...
No trim required.
Keith
Wheelie58
Wheelie58
Post  Lem Evans October 23rd 2015, 6:17 pm
5pointslow wrote:using a stock crank with Sfi romac balancer
The stock length space is ~ 2-3/4" as best as I can remember.
Post  supervel45 October 23rd 2015, 7:32 pm
Do you have a stock balancer you could compare the height to? If they are the same height or shaft lenght, I cannot see any difference, unless the wheel where thicker and rubbing something on the back side.
