Going from standard snout to boss snout crank
Going from standard snout to boss snout crank Empty Going from standard snout to boss snout crank
Post  KY JELLY May 9th 2014, 4:36 pm
I had not saw this posted before so though I would pass it along.
If you change from regular 460 crank to boss length snout you
Need about 1 3/4 " spacer on the drive mandrel / spline drive to keep your
Oil pump and such in the same location.
Going from standard snout to boss snout crank Image_zps78fadf2d
KY JELLY
KY JELLY
Going from standard snout to boss snout crank Empty Re: Going from standard snout to boss snout crank
Post  Wheelie58 May 9th 2014, 7:55 pm
Nice timing pointer and motor plate.
Wheelie58
Wheelie58
