Boss snout crankshaft
Boss snout crankshaft Empty Boss snout crankshaft
Post  STR-LGL-70 March 28th 2017, 6:05 pm
What is the main reason to use boss snout? Ready to purchase new crank but have fluidampner for standard length I'm already using. Also fluidampner is pretty old, do they go bad? Currently running enderle belt drive pump & alternator off of standard length crank.
Thanks!
Sheldon G.
STR-LGL-70
STR-LGL-70
Boss snout crankshaft Empty Re: Boss snout crankshaft
Post  Frank Merkl March 28th 2017, 10:25 pm
throw the fluidampner away! the short snout moves the dampner closer to the front rod throw and takes whip out of the crank on the front rod throw were I've broke 3 cranks over the years . short snout for the last 15 years and no broken cranks
Post  cool40 March 28th 2017, 11:25 pm
Frank Merkl wrote:throw the fluidampner away! the short snout moves the dampner closer to the front rod throw and takes whip out of the crank on the front rod throw were I've broke 3 cranks over the years . short snout for the last 15 years and no broken cranks
x10! That pos probably weighs 10#!
Post  rmcomprandy March 28th 2017, 11:31 pm
A lot of engines are even built with a small block length snout, (5/8" shorter yet), in order to be able to use a small block size damper and then not need any spacer at all.
