Crankshaft snout
galaxie500
Crankshaft snout
Thinking about having my 5" snout cut down. The bolt hole is drilled 2" deep, is it necessary to drill the new hole this deep?
galaxie500- Posts : 2
Re: Crankshaft snout
I'd say yes, The Factory did it for a reason.
the Question is whydo you think you have to cut your crank off? there has to be some reason for you wanting to do it?
the Coug- Posts : 3055
I think it's just to long in the dragster. BBC and BBM are drilled approx 1 1/4" deep.
They also have fatter snouts I believe.
I think it's just to long in the dragster. BBC and BBM are drilled aprox 1 1/4" deep.
and it ant no cheby
and it ant no cheby
res0rli9- BBF CONTRIBUTOR
you know there are lots of 1000+ hp engines running on here with the longer snouts... These are not Big Block Chevies or Mopars (Bandaids) so quit talking like they are... Please... Read and adsorb info...
I don't have any Boss Snouts to Measure, are the Boss ones 2" Deep? Randy?
galaxie500 wrote:I think it's just to long in the dragster.
What brand dragster and what wheelbase? I had a 225" Undercover. I had a bbf with the long snout in it + a 4" long mandrel on the front of it for the belt drive fuel pump. The bolt head at the the front of the mandrel was about 2 3/4" from the blow shield.
Dave one of my Boss Cranks the bolt hole is 1.83 deep... I just checked one... but I think they should be close .....
David Cole wrote:galaxie500 wrote:I think it's just to long in the dragster.
Some of us have a radiator behind the blow shield. With a boss snout and a Ron's mandrel, my old balancer bolt head was about 1/4" away from the fan shroud. I'm hoping with the new set up, that I will have 1/2".
Curt- Posts : 2791
» Boss snout crankshaft
» crankshaft front snout lenght
» Boss crank snout.
» Going from standard snout to boss snout crank
» Balancer on long snout crank
» Boss crank snout.
