Cant spin the cam by hand ?
+9
83-88T-Bird Guy
bb429power
nuclearcobra
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
so i got it out by turning the cam handle with a wrench while i pulled on it and tried puttin in my old cam and i can spin that by hand you think the new cam is warped maybe ? or the journals on the old cam are worn just enough to get it to turn ? just wondering if its the new bearings i put in last nite or the cam ?
nuclearcobra- BBF CONTRIBUTOR
Re: Cant spin the cam by hand ?
Lem Evans wrote:The cam needs to turn free.
X2
mic the old and the new journals and you'll find your answer
Frank Merkl- Posts : 1524
Gonna do that now
as your installing the cam,does it turn hard starting w/1st journal,or one of the other journals.Sometimes if the first or last bearing is not square it will turn really hard.
Heck mine wouldn't even go in so I went to exchange it and then UPS lost it.
bb429power- Posts : 3129
I had a local machine shop hot tank my 460 block and install new cam bearings one time.
Got it home and started to slide the cam in.
2nd journal was snug, but by the 3rd journal there was no was it was going in.
Took it back to the shop and the knowledgable shop owner knew what the problem was. So he pops out the bearings and hones them and then the cam slides in as normal. He said that some 460s had core shift in the cam tunnel area.
Apparently, the newbie at the shop was the original installer.
83-88T-Bird Guy- Posts : 1003
Well everything seem to mic ok but just to be sure cause i'm new at measuring with one i took out the lunati cam i put in my buddys motor (i'm building two side by side) and it spins fine in my motor just like the comp cam did so thats two that are fine in my block. So just to triple check i put my new cam in my buddys block and it spins fine so i just took it out and put in in my block again and its locked up just like it was.
Have had that happen more than once from machine shops here, and when I pulled them out and pulled a new set in carefully the problem went away.
More times than not the brg's were battered and swelled from being knocked in. Then if your machinist honed them and put them back in, your oil clearance will be too great. Also you have lost some of the brg. crush.
I wonder if both cam and block are off a little and both combined its not enough clearance kinda like swaping bearing halves to get the clearance you wan't ? i tried my cam in the other block and it spins fine and i tried two diffrent ones in my block and they spin fine.
Well i hope its not the bearing installer i'll fire myself thats why i tried two other cams to see if it was a bearing but they spun fine and to eliminate my cam being bent i tried it in the other block and it spun fine so now i'm stumped
did the other block have new bearings
nuclearcobra wrote:Well i hope its not the bearing installer i'll fire myself thats why i tried two other cams to see if it was a bearing but they spun fine and to eliminate my cam being bent i tried it in the other block and it spun fine so now i'm stumped
check the cam , maybe a polish is in order, or cam bearings need fitted,
BOSS 429- Posts : 2372
yes i put new bearings in both motors last nite, i guess i'll try to polish the journals first then if i have too i'll take out the bearings and go get a new oil plug (i knew i should have waited to put that in)
Does it lock down as soon as you slide it in or after you put the cam gear on.
soon as i slide it in and i can turn it but i need a wrench i can't even turn it by the cam handle.
go to chat its easier to talk about this ,lol
http://460chat.com/
Maybe its the brand. LUNATI, mine is a Lunati too. Makes me question them.nuclearcobra wrote:Well everything seem to mic ok but just to be sure cause i'm new at measuring with one i took out the lunati cam i put in my buddys motor (i'm building two side by side) and it spins fine in my motor just like the comp cam did so thats two that are fine in my block. So just to triple check i put my new cam in my buddys block and it spins fine so i just took it out and put in in my block again and its locked up just like it was.
Tuesdays and Saturdays at approx. 8:00. A lot can be learned in the chat room.BOSS 429 wrote:http://460chat.com/
bb429power wrote:Tuesdays and Saturdays at approx. 8:00. A lot can be learned in the chat room.BOSS 429 wrote:http://460chat.com/
huh? we were there last night?
Last night was Sunday, its Tue. and Sat. why no one was there when you went?BOSS 429 wrote:bb429power wrote:Tuesdays and Saturdays at approx. 8:00. A lot can be learned in the chat room.BOSS 429 wrote:http://460chat.com/
83-88T-Bird Guy wrote:I had a local machine shop hot tank my 460 block and install new cam bearings one time.
Had the same issue. My guy did the block and sent it back to me bare, I installed the cam and found the issue. Took it back to him with the cam and he made it right as can be. Said the same thing about the shift issue. A little hone goes a long way!
kjett- Posts : 1169
Page 1 of 2 • 1, 2
» 1/2 X 24 left hand tap
» Interesting how they spin their wheels
» When leaving on transbrake how much tire spin to hurt 60ft?
» Warning!!!!!!
» FireCore50 Ignition Wires / QFT Carbs
» Warning!!!!!!
Page 1 of 2
