Overdrive for 85 Ford 1 ton?
Is there a good way to add overdrive to an 85 Ford 1 ton, 460, 4 speed? Found a great deal on a super clean 1 ton dually but I'm assuming gas mileage was crap back then so looking for ways to improve.
512Fairlane- Posts : 694
Re: Overdrive for 85 Ford 1 ton?
If you could find a used gear vendors would be easiest. A friend of mine bought an old used class c for $1500 that had one, took the overdrive off of the C6 and resold it for $1500. That is such a good deal you would think it happened to Blake.
jasonf- BBF CONTRIBUTOR
ZF5 or E4OD Both came stock behind 460's
otherwise the gear vendors way.
Diggindeeper- Posts : 800
Thanks. I didn't realize they had the E40D behind them.
Didn't the E4OD start in 1988 ?
83-88T-Bird Guy- Posts : 1003
» RV Trans swap
» What transmissions are available?
» C-6 overdrive unit
» We had a forum member set low ET for a Ford at the Annual Ford v Chevy race last weekend.
» Let's see your "unusual"Cool HotRod pic's. Ford and Non Ford
