Cast core solid roller cams
Greg_P
Cast core solid roller cams Empty Cast core solid roller cams
Post  BigBlockRanger September 1st 2009, 12:26 pm
Just picked up a used Herbert cam (HERCH6K) for the BBR and was a little disappointed to find it is a cast core roller cam.
Input? I am a little concerned about using it.
Cast core solid roller cams Empty Re: Cast core solid roller cams
Post  dfree383 September 1st 2009, 12:34 pm
I wouldn't use one.
Post  BigBlockRanger September 1st 2009, 6:16 pm
Ah hell I though you were gonna say that.
Post  Lem Evans September 1st 2009, 6:47 pm
F.Y.I. all of the Comp rollers...hyd or solid are billet .
Post  rmcomprandy September 1st 2009, 7:16 pm
Those cast cores are the same "DUCTILE IRON" material which the factory hydraulic roller cores are made from.
Although it is cast, it is NOT simply cast IRON like a flat tappet core.
I wouldn't be afraid of it - IF it is not a radical flank lobe profile.
Post  BigBlockRanger September 1st 2009, 9:23 pm
This is a used cam and here's what got me started thinking about it: There is the tiniest of tiny little ridge on either side of the wheel track on the opening ramp of most lobes. Like the spring pressures were too high. The rest of each lobe looks fine. It is not a radical profile at all.
Cast core solid roller cams 2z56m2b
I may just go with my #2 option which is have my current billet cam reground by Delta.
Post  dfree383 September 1st 2009, 9:31 pm
rmcomprandy wrote:Those cast cores are the same "DUCTILE IRON" material which the factory hydraulic roller cores are made from.
Ive never seen a factory for cast roller cam??? What models didthose come in?
Post  Greg_P September 1st 2009, 9:45 pm
Dam man, I hate to be the guy to tell you this, but saving $12.00 on a used cam just isn't worth it.
Have your old acm reground, or switch to a solid flat tappet.
Greg
Greg_P
Greg_P
Post  richter69 September 1st 2009, 9:50 pm
That cam is f-cked.
Post  BigBlockRanger September 2nd 2009, 9:35 am
Greg_P wrote:Dam man, I hate to be the guy to tell you this, but saving $12.00 on a used cam just isn't worth it.
Greg
Aww comeon! That $12 is my lunch money for the week!
jocolor
Post  rmcomprandy September 2nd 2009, 10:19 am
There were several engines which had cast DUCTILE iron hydraulic roller cores.
Pontiac Iron Duke 4 cylinder engines and Buick V-6's come to mind as well as some early 302 Ford Crown Vic, (302 firing order), camshafts.
The aftermarket cast core camshafts use that material.
Post  chuck stevens September 2nd 2009, 12:40 pm
"Back in the day", before steel billets were easily available, hi density cast cam cores were what most used. I gave, in the shop, 3 cast billet "Proferall" core cams, circa 1970, they are all Top Fuel solid roller cams 2 ENGLE's and 1 HOWARD. The spring setup, on these, is #200 to 220 on the seat and #390 to 425 OTN. Specs on the ENGLE's: Grind# L-169, IO 31° BTDC, IC 71° ABDC, EO 71° BBDC, EC 31° ATDC. Lash .020/.022, valve lift .548, gross cam lift .365, rocker ratio 1.5:1, duration @ .050 282°, 110° lobe centers. They are "Big Nasty Mutthas" currently in use for Nostalgia Top Fuel and Cackle Cars. Both these cams have just been "touched up" by ENGLE and look like new. The cam shown in the picture could easily be "touched up" by the original grinder or, altered slightly to an improved profile. NOTE!!! these were SERIOUS drag race ONLY cams for engines built to run 1320 feet....not 1321 feet. ALL of the flat tappet cams we ran in my old "Top Gas" dragster were these same cast billets and 39 years ago, to the day, we spun the motor PAST 11,000 RPM TWICE...and it lived.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  moparman September 2nd 2009, 10:54 pm
The real advantage to that cam is you can use a cast dizzy gear instead of a bronze one... You're not planning on running crazy spring pressures are you?
moparman
moparman
Post  BigBlockRanger September 3rd 2009, 12:12 am
No crazy springs here. 215/550
I will just have my existing steel cam reground. I am not going to chance it. I want to drive this thing!
Post  Diggindeeper September 3rd 2009, 12:14 am
what are the specs on said cam anyway??
Diggindeeper
Diggindeeper
Post  BigBlockRanger September 3rd 2009, 8:13 am
RPM Range: 2500-6800
Advertised Duration: 286/290
Duration @ .050: 246/253
Lift: .663/.680
Lobe Center: 108c
