Turbo Charging a '94 F350 7.5L
+8
83-88T-Bird Guy
AK
EVE
JR Performance Motorsport
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
I am looking for any info from you guys about undertaking this. The truck is a strong running 460 with a E40D trans. I posted this about 9-12 months ago on the other site but have not been able to find it. I need to know the pros and cons of this. I am also wondering how much boost and the size of the turbo, for the RPM range it will opperate in. Now the truck has 4:10 gears but I am switching it to 3:55 for better fuel milage. The purpose of me wanting to put a turbo on is to get better pulling power and milage, this is not a race car. I run with the 3:55 gears daily around 1600 - 1900rpms @ 70mph, I have very rairly seen 4Krpms. I am working on setting this truck up for long hauls, being we are racing this season in Idaho and Washington. With the expected gas cost increase I need the best milage possible. Now if it jumps up in power from the 285hp and 425ftlbs that will be great as well.
Thank you
Jim
928-219-4929
eperformancemarine@yahoo.com
Thank you
Jim
928-219-4929
Re: Turbo Charging a '94 F350 7.5L
A turbo won't help your mileage. W aren't talking about a diesel here.
EVE- Posts : 124
Nope it is a 7.5L/460 ! Now why would it not, as you would have more power in all gears? This would allow me to stay in 4th/OD while climbing a hill with a load, in turn better milage. Now it seems that having more power would use more fuel, but if you don't have to use more throttle you could get better milage right ?EVE wrote:A turbo won't help your mileage. W aren't talking about a diesel here.
I have never heard of a turbo conversion that did not get better mileage. you would need to discuss your wishes with a reputable turbo dealer for specs on the turbo you need. what you would be looking for would be more of a diesel type turbo than one like on our ride which is intended for high rpm use. good luck.
whatbumper- Posts : 3024
You might want to go this route...........................
http://www.ford-trucks.com/forums/972149-1996-f250-460-baseline-dyno-results-and-head-porting-info-results-are-in.html
Read it all the way to the end.
you'll need to beef up the E40D as well..........
I dont see how mpg could possibly improve. Your effiency (Brake Specific Fuel Consumption, BSFC) will probably improve but you have to burn more gas when you put in more air at any rpm.
You could train yourself to use the higher gears and suffer the low power to improve mpg.
The turbo is like artificial cubic inches and more C.I. burns more gas.
AK- Posts : 67
AK wrote:I dont see how mpg could possibly improve. Your effiency (Brake Specific Fuel Consumption, BSFC) will probably improve but you have to burn more gas when you put in more air at any rpm.
I don't follow your reasoning. Some of what you are saying is true, some is true but not applicable, and some is wrong.
JR Performance Motorsport wrote:Nope it is a 7.5L/460 ! Now why would it not, as you would have more power in all gears? This would allow me to stay in 4th/OD while climbing a hill with a load, in turn better milage. Now it seems that having more power would use more fuel, but if you don't have to use more throttle you could get better milage right ?EVE wrote:A turbo won't help your mileage. W aren't talking about a diesel here.
You won't have more power unless your in boost. It will act just like a N/A engine until the boost comes on and if you want to tow a trailer up a long hill with boost then good luck and I hope you run race gas. Another problem with it is that you will be running smaller turbos to get it to spool at a lower RPM and that's going to make your IAT's even higher and cause detonation that much easier. Diesels like boost because it cools down the exhaust gas and makes the fuel burn more efficiently. They benefit from more boost up to a point. If your EGT's on your diesel are high throw a bigger turbo on it and it will cool them down and fuel mileage while in boost will improve. This logic does not work with a gas engine. Your best bet is to lower RPM's as someone else stated above. Look into a gear vendors overdrive.
EVE- Posts : 124
whatbumperu wrote: I don't follow your reasoning. Some of what you are saying is true, some is true but not applicable, and some is wrong.
What I'm saying is, Your engine will become more efficient at making power, (HP per CI). But at the cost of more fuel. The only way I see that you could improve MPG is if the turbocharger was going to correct a rich condition, which it will not IMO. Fuel + air in = power out. Not just more air. You still have to maintain an air/fuel ratio, so more air in = more fuel in.
I'm not going to claim to be an expert but I think I'm giving a very basic answer to a very complex question. If I'm wrong feel free to correct me.
AK- Posts : 67
I see no reason why mpg would not increase with the turbo installed if the right foot is applied the same.
The benefit of the turbo is that you can switch from 4.10s to a 3.73 gear and still pull a hill the same.
Turbos help build low rpm torque, so those deep gears are not necessary.
I just put the 460 out of my race car into my '84 F350 Crew Cab and had thought about mounting a turbo in the bed of the truck.
All that engine needs is 5-6 lbs of boost.
Then I could swap the 4.10 Dana 60 for a 3.55 Sterling 10.25 rear.
That would drop my cruising RPM by over 13%.
83-88T-Bird Guy- Posts : 1003
Heres a rpm/mph calculator. I'm not sure what the OD ratio is but 4.11 to 3.55 will only change rpm roughly 300-400 rpm at any given speed
http://www.bgsoflex.com/rpmmph.html
Lowering the rpm without a turbo will lower fuel consumption but with the added fuel for 5-6 # of boost you might break even, more, or less. It all depends how much more fuel it takes to keep a decent A/F ratio. It will be interesting to know how it turns out.
AK- Posts : 67
Well I am doing the gear swap/rearend from 4:10 to 3:55, this allone should get me at least 2mpg better. Now the turbo should imo help me pull the gear without dropping a gear going up a hill. I am going to do a throttle body switch as it seems they use the same ones on the 5.0, 5.8 & the 7.5L truck engines. I saw some where that they make a larger one and as we all know 460s/BBFs love big carbs. So more air in with this may help. I am going to get some baseline info first then make changes. I am going to try and document everything I do on this and see where it leads.
Thanks for all the info.
just put a Blower on it, instant trq.
res0rli9- BBF CONTRIBUTOR
My opinion is worth twice as much as you paid for it:
Simply adding a turbo to a NA 460 cid engine will not increase fuel economy. In fact, a turbo decreases BSFC. It is possible that changing the combo (gearing, trans, tune, ect) may net enough improved economy to make up for the decreased efficiency, though.
Now, IMHO, the reason you see turbos used is that you can put a turbo on a smaller engine and get comparable hp/torque to a larger cid engine. The fuel economy of the smaller, turbocharged engine may get better fuel economy than the larger, NA engine even though both may have the similar hp/torque #'s. So, a fairer question might be, "Will a turbocharged 460cid get better fuel economy than a NA 557 cid engine?"
Have a good day!
Michael
Have a good day!
Michael
96Mustang460cid- Posts : 154
Another question I'd consider:
How long will it take to pay for the modifications being considered? If you spend $2,000 on a turbo setup, custom tune, gears, ect, ect, to improve your fuel mpg by 2 mpg (10 mpg to 12 mpg), it will take 43,000+ miles @ $2.75/gal to break even on the venture. This doesn't account for the potential increase in fuel cost (higher octane?), increased maintenance costs (oil change interval, spark plugs, ect), or the risk of undertaking a project that could ruin a perfectly good engine in a heartbeat.
Have a good day!
Michael
Have a good day!
Michael
I would think, most that add chargers to their 460's are just looking for the extra towing power, and if cruise mileage stays the same it's just a plus..............
My 2002 Lightning gets about the same as a regular 1/2 ton pick up with the same rear gears, and it has a super charger on it. It is driven everyday and runs 12.90's through the quarter on street tires.
Turbo's and super chargers are cool..........................
I rode with Blake to the Columbus Swap Meet last year in his truck. I've never been so impressed with the way anything ran as I was his truck. That thing is scary fast and the excelleration is just way BADAZZ. You'd never know it was bad at all under normal driving ,but when that thing starts that silly whistling...you'd better be hangin on and pointed the right way.We passed a car on the interstate running about 70 MPH by the time we were around it we were about 110MPH in just a few seconds. That's just a super set up. I was Totally impressed with that SVO (Inside Joke)
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:I rode with Blake to the Columbus Swap Meet last year in his truck. I've never been so impressed with the way anything ran as I was his truck. That thing is scary fast and the excelleration is just way BADAZZ. You'd never know it was bad at all under normal driving ,but when that thing starts that silly whistling...you'd better be hangin on and pointed the right way.We passed a car on the interstate running about 70 MPH by the time we were around it we were about 110MPH in just a few seconds. That's just a super set up. I was Totally impressed with that SVO (Inside Joke)
I would still like to here what it would take to be able to add say two t-3's and an intercooler to an efi 460 in a truck. It's a speed density deal. Would just some way to add fuel be all you need?
IDT-572 wrote:I would still like to here what it would take to be able to add say two t-3's and an intercooler to an efi 460 in a truck. It's a speed density deal. Would just some way to add fuel be all you need?
Blake,
my buddy put a Turbo on his F-350 dually with a 460 and mounted it underneath the truck.He kept the speed density deal but had some gremblems with it.He wasn't sure if it was from using the speed density setup or the turbo was to small.I you're interested i have some pictures of it on his truck i could e-mail you.He took the setup off his truck and was trying to sell it.
Later Mark.
Mark Miller- Posts : 1948
Thanks Mark I would like to see them.
Mabe blake can do like I had my lighting setup.... add a 100 shot of N2O.
With the powdered metal rods, low eights are as fast as you need to go. NOS is good in boosted applications, more fuel and air and good for cooling the air charge (inter-cooling)
When it needs a refreshing I will up grade the rods and pistons and put on the new TFS -R heads.............
Mark Miller wrote:
Blake,
Later Mark.
I remember reading years ago where someone put a turbo on a 86 Mustang 5.0 with speed density and ran into a similar problem.
He ended up putting a 1-way vacumm valve near the map sensor.
I assume it was to prevent the map sensor from "seeing" a boost condition but allow the map sensor to work normal under cruising high vacumm conditions.
That one thing has stuck in my head about speed density and boosted engines.
Page 1 of 2 • 1, 2
» Not sure where I should post this ??? about my 76 F-100 charging system......
» Vehicle Electrical Charging System.
» twin turbo 521 turbo specs
» C intake or turbo hat turbo headers
» F350 does it.....
» F350 does it.....
Page 1 of 2
