Transmission weight
TommyK
GTmustang
whitefield
Transmission weight Empty Transmission weight
Post  whitefield January 31st 2011, 11:21 am
FORD GM Power Glide
C-6 173lbs TH400 181lbs
c-4 135lbs TH350 165lbs
AOD 700R4
All Transmissions were weight dry and with dipstick tube, converter and mounts . These transmissions where all stock and with stock converters.
I will be adding weights and more transmissions .
The above weights are mine the below weights are what I found on my search for more trans info
Ford -O-Matic 228lbs
FMX 160lbs
C4 110lbs
C6 140lbs
AOD 150lbs
Trans Bellhousing
Face to Trans
Mount Length Overall Length
From Bellhousing
To Tailshaft End
C4 20¼-inches 30½-inches
C6 22½-inches 33½-inches
AOD 22¼-inches 30¾-inches
E4OD 29 3/8-inches 37½-inches
whitefield
whitefield
Transmission weight Empty Re: Transmission weight
Post  dfree383 January 31st 2011, 2:55 pm
Interesting data...... I'm assuming weight is with a stock convertor?
Post  whitefield January 31st 2011, 3:10 pm
yes , I will keep this up dated and edit/change data as I keep checking to make sure that what I post is fact.
whitefield
whitefield
Post  GTmustang February 12th 2011, 9:30 am
Can this be made a sticky so that everyone can find it easily for reference. I was surprised that the Turbo 400 and 350 weighed more than their Ford counterparts!
Gary
GTmustang
Post  TommyK February 12th 2011, 7:00 pm
FWIW parasitic HP loss as published by Carcraft
Powerglide_____18 hp
TH-350________36 hp
TH-400________44 hp
Ford_C-6______55-60 hp
Ford_C-4______28 hp
Ford_FMX______25 hp
Chrysler_A904__25 hp
Chrysler_727___45 hp
TommyK
Post  richter69 February 12th 2011, 7:03 pm
an e4od 4r100 is just shy of 300#s w converter................ Wink
Post  TommyK February 12th 2011, 7:07 pm
Excerpted info originally posted by Dan Jones:
Transmission Weights
AOD (without converter or fluid) - 150 lbs
AOD stock torque converter - 34 lbs
C4 (without converter or fluid) - 110 lbs
C4 torque converter - ? lbs
C6 (without converter or fluid) - 140 lbs
C6 torque converter - 30 lbs small block, 31 lbs big block
FMX (without torque converter, unknown fluid level) - 160 lbs
FMX torque converter - 32 lbs
Ford-o-Matic (pre-FMX), cast iron case - 228 lbs
Notes:
- AOD and C4 weights are as measured by me using a standard bathroom scale.
- FMX and C6 torque converter weights provided by Steve Grossen (also used
bathroom scale).
- Ford-o-Matic weight is an assembly line weight provided by my Dad.
- C6 weight is from "Engine Swapping Tips and Techniques" which also lists
the C4 at 109 lbs.
TommyK
Post  Tennessee Bullitt February 12th 2011, 9:37 pm
Thats OK my C6 will stand numerous beatings isn't that right Mike.
Tennessee Bullitt
Tennessee Bullitt
Post  whitefield February 13th 2011, 3:47 pm
TommyK wrote:FWIW parasitic HP loss as published by Carcraft
TH-350________36 hp
TH-400________44 hp
Ford_C-4______28 hp
Ford_FMX______25 hp
These Numbers where with stock not hp transmissions taken 20 plus years ago.
whitefield
whitefield
Post  richter69 February 13th 2011, 4:36 pm
I'd bet money a 6r80 trans has the least amount of parasitic drag in 1-1..............no bands or one way rollers ...
Post  lghting94 February 13th 2011, 6:10 pm
I would like to see what the parasitic drag of a full race prepped and rollerized c-6 is. My guess would be in full race trim and rollerized that all transmissions would become extremely close in parisitic loss.
lghting94
lghting94
Post  BIGDOG466 February 14th 2011, 5:37 pm
I took out a C-6 and installed a Power Glide and the glide weighed 15 lbs less,
Glide was JW case with bell full roller with 9" conv. with a quart in conv.
, C6 was pulled fluid drained but 9" conv. was full
A stock case would weigh less but I didn't trust it behind a BBF Very Happy Very Happy
BIGDOG466
BIGDOG466
Post  83-88T-Bird Guy March 8th 2011, 9:07 am
Great thread !
Good info.
I see there is 40 lbs diff. between a C-6 and C-4. Good to know.
83-88T-Bird Guy
83-88T-Bird Guy
