N/A Low 5's doable Yes or No Lets Hear It
+11
KY JELLY
138
Tennessee Bullitt
LBSRACING
15 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: N/A Low 5's doable Yes or No Lets Hear It
And also there is the point of the small tire thing..................anything n/a is gonna be hard as hell due to the fact even max effort it will be tough to get there and that's gonna be using every ounce of power through the whole pass.
Your gonna need to make way more power than is needed to run the numbers as your gonna have to kill it down low to make the tire work.
Big bore short stroke with a progressive nitrous system or even a turbo with a boost controller etc IMO is the ticket..and yes the Ford stuff can be competitive.
This is were I think running EFI will help.
LBSRACING- Posts : 32
LBSRACING wrote:This is were I think running EFI will help.
Exactly how do you think EFI is going to help?
dfree383 wrote:LBSRACING wrote:This is were I think running EFI will help.
Yeah should have woke up a little more before that post. AT the time I was thinking can pull timing and fuel but it would never recover like a forced induction car I guess. Things sure did seem alot simpler back in 2000 when outlaw 10.5 was running 4.80's all day and we had a 632 chevy on 3 guns lol. I'm starting to look more into a A head with fogger. Still up for debated though
comparing efi to carb n/a bbf ....... i dont see a difference ...its all the end user, suspension, tuner and track conditions ...
wouldn't BT thors be considered as nonconventional as the c heads and big chiefs
simpleman- Posts : 57
simpleman wrote:wouldn't BT thors be considered as nonconventional as the c heads and big chiefs
I don't know if the Thor's with their cavernous ports would work well on an engine with only 588ci.
schmitty- Posts : 4538
A heads are conventional according to John Sears the creator of the rules. A head standard deck height N/A 2900 lbs
A head standard deck w/nitrous 3250lbs
http://www.yellowbullet.com/forum/showthread.php?p=5064541#post5064541 go to post #50
http://www.yellowbullet.com/forum/showthread.php?t=312921&page=38 Pg 38 post # 563
bad572- Posts : 15
still thinking about running x275. I think with the weight and the A heads a competitive combo can be run in this class.
bad572- Posts : 15
still thinking n/a and take the weight break?
138- Posts : 1593
Yeah still considering this set up. After seeing the 4.80's I don't have enough car for that. So thinking of picking up another car later in the year maybe. I will be home for good in December so I will be able to finish things up before next year. Right now though the plan is to just spray the crap out of my 545 I have now.
LBSRACING wrote:Yeah still considering this set up. After seeing the 4.80's I don't have enough car for that. So thinking of picking up another car later in the year maybe. I will be home for good in December so I will be able to finish things up before next year. Right now though the plan is to just spray the crap out of my 545 I have now.
I like that plan. Dont let the guys at the big events times scare you. I think this class at the local level if you can do consistent 5.20's you will top of the heap.
bad572- Posts : 15
» ROLLER or FLAT CAM?
» Looks like Jones is stepping down?
» What every father wants to hear.
» Another hp guess
» Hobbs crash landed
» Another hp guess
Page 3 of 3
