ROCKER ARM QUESTION
ROCKER ARM QUESTION
Does any one know how much changing from a Harland sharp rocker arm to a to a trick flow rocker arm will effect push rod length.My pattern is ok but rolls over center just a tic more than I would like. shorter push rods would be a problem due to guide plate interference lash caps are not a optoin because of type of keepers.I had a similar problem in the past and changed to trick flows it fixed the problem but I can't rember how much it changed the push rod length. It will run as is,but I was thinking that if it would help I would order a set of trick flows and use the harland sharps on a back up motor.Thanks for your help Ward
Re: ROCKER ARM QUESTION
Ward, if your planning to buy rockers you should take a hard look at these (www.mid-lift.com) I bought a set, one of the best rockers I've ever seen! & the tech info opend my eyes to all the geometry questions you are talking about. hope this helps.
Terry
Terry
The wipe pattern location is almost immaterial as long as it is not near the edge of the valve tip. Concern yourself with the rest of the geometry.
What Randy is saying,,,,,, and it was his subject matter (as guest speaker at our 2008 Winter Tech Seminar at the Executive Inn in Owensboro, KY), that the intersection angle of the pushrod to rocker arm cup needs to be looked at long and hard. There ain't no roller there. Basically I suggest you follow his advice.
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
spent the week end reading and tweaking things,thanks for the advice it cleared up what I was asking Ward
» valve train/roller rocker question
» Acceptable roller rocker contact at valve tip and pushrod to rocker contact?
» Big lobe & lower ratio rocker or smaller lobe & high ratio rocker? whcih will live and which makes more power?
» Rocker arm?
» Rocker arm?
