Ignition Switch Confusion
bb429power
TheFrog
Here's something strange:
I went to crank my 429-460 for the first time today and found that when I turned the key to the "On" position the motor began to crank. Then I turned the key to the "Acc" position and the motor once again began to crank.
If I'm not mistaken, isn't the only position the motor is supposed to crank in is the "Start" position?
What in the world did I do wrong??
Thanks,
Keith
Thanks,
Keith
TheFrog- Posts : 81
Re: Ignition Switch Confusion
Correct, the "on" and "acc" just turn the power on. "start" has the power on and at the same time gives power to the starting system to crank the engine over. You may have something cross wired or in the wrong spot at the starter solenoid or at the ignition switch.TheFrog wrote:Here's something strange:
bb429power- Posts : 3129
fastfrog what starter you have sounds like you have the wrong wire hooked to the soliniod
Thanks guys!
I also e-mailed the manufacturer of the wiring harness I'm using and he said something close to what you guys said. He said that I probably connected the "start wire" to the "accessory post" at the Ignition Switch. I hope to look into it tomorrow.
Thanks again guys. We'll see if it works tomorrow!
Keith
Keith
TheFrog- Posts : 81
Ugh, I can't seem to figure this out!
Does anyone happen to know which post is which on the reverse side of a 62 Galaxie Ignition Switch? I need to figure out which post is Batt, Acc, Ign and Start. Why the heck didn't Ford label these??
Thanks,
Keith
Thanks,
Keith
TheFrog- Posts : 81
I don't have a schematic. But you should be able to figure it out with a test light
jbozzelle- Posts : 3705
jbozzelle wrote:I don't have a schematic. But you should be able to figure it out with a test light
....or an ohm meter.
maverick- BBF CONTRIBUTOR
TheFrog wrote:Ugh, I can't seem to figure this out!
Thanks,
Keith
Can you post up a pic of the back of the switch, I mite have a schematic.
or email a pic to...kthmerchant@gmail.com
Keith
res0rli9- BBF CONTRIBUTOR
I don't know of ANY Ford ignition switch which connects directly to the starter.
BOTH wires from a gear reduction starter are connected to the solenoid mounted usually on the fenderwell.
do you have power to the ignition with key on acc ? dont know what type of car you have or solenoid . now if the answer to my question is yes and you have a 4 post solenoid (2 large 2 small post) you could have the 2 small wires switched
DanH- Posts : 1081
look here find the switch and starter relay, get the number of wire and on the right side of 2nd page get the wire collar,this is a truck but switch and relay are wired the same.
http://www.wingsisp.com/emboss/schem1.htm
http://www.wingsisp.com/emboss/schem2.htm
Thanks everyone for the resources and help! It's really appreciated.
Get this! I ended up purchasing a Universal Ignition Switch to bench test my wires since the Ignition Switch I had kept giving me no reading of power on the "Start" post when the Switch was in the "Start" position. I ended up getting power to all posts on the Universal Switch which solved this whole problem!!!! What are the odds of that?
Anyway, it ended up being a really easy and inexpensive fix to a complicated problem.
Thanks again!
Keith
Thanks again!
Keith
TheFrog- Posts : 81
» Just so there is no confusion
» What all do i need to switch my 460 to run e85
» Pilot Bushing Confusion-Need Help
» MSD rpm activated switch SOLD
» electric pumps
» electric pumps
