need help new build
Tennessee Bullitt
mac460
need help new build Empty need help new build
Post  mac460 February 14th 2011, 8:34 pm
ok doing a scat forged 545 stroker in 70 block . need help picking a roller cam and torque converter. going into a 84 mustang coupe streetcar.the car is minn tubed. 29-10.5w, 8.8 355 gears
c-6. upr tube k-frame flaming river rack and coil overs all around with willwood brakes all 4 corners.
theyes are the parts i have right now
scat 545 stroker kit
Trick Flow® PowerPort® 290 Cylinder Heads that have been ported will add the flow # at the end
4500 victor intake ported to heads
comp cams Endure-X™ Solid Roller Lifters
all arp fasners
sfi powerbound balancer
sfi flexplate
Scorpion #1023 roller rockers 1.73
canton oil pan #15-770
msd Pro Billet Distributor #8577
MSD Digital-6 Plus
holley 150 GPH Billet Base HP Fuel
head flow # are after porting
intake .100=72, .200=152, .300=232, .400=290, .500=343, .600=368, .650= 369 .700=368, cfm.
Exhaust; .100=54, .200=108, .300=141, .400=177, .500=208, .600=232, .650=242. 700=251.cfm.
so now i need help picking a cam , torque converter ,carb, and headers
mac460
mac460
need help new build Empty Re: need help new build
Post  Tennessee Bullitt February 14th 2011, 8:49 pm
Call Lem Evans for your cam, he can pretty much hit it on the head for you. D&D makes some good headders but since you already have the tublar k-member, dynatech just released 2 1/8 headders to clear C6 trans with deep pans. They work with AJE and UPR k-members. Converter I would say call PTC after you get a cam set up. I got a 10" SS converter for $425 and I has all the good stuff and it stalls just like it's designed for. They get in dept with all your stuff, having the car weight will help or pretty close. It is a real good converter, they also have all different sizes as well. Carb I would say a good 1150 or 1250 dominator but mabe someone else might pin point it for you. Lem will be able to tell you what is best for your setup as far as a carb.
Tennessee Bullitt
Tennessee Bullitt
Post  mac460 February 16th 2011, 1:54 am
thanks . will also be useing a motor plate. iam trying to figure out a starting place on parts . from the people that have did this before . it will be a street/strip car . the lifters will be replace yearly. and get rebuilt and used the next year.i woud like to make 700hp at the wheels if i can and still make it live on the stret
mac460
mac460
Post  Tennessee Bullitt February 16th 2011, 7:52 am
How many rpm's?
Tennessee Bullitt
Tennessee Bullitt
Post  mac460 February 16th 2011, 12:23 pm
will try to keep it under 7000 rpm. it will have 10.2-1 comp
mac460
mac460
Post  rmcomprandy February 16th 2011, 12:48 pm
A 700 horsepower everyday streetable 545 engine will probably be under 6,000 RPM.
The heads must be ported to the intake as it has slightly different location ports already.
Post  dfree383 February 16th 2011, 12:53 pm
"700hp at the wheels" may be a little bit optomistic with a 10.2:1 engine IMO
Post  mac460 February 16th 2011, 3:29 pm
rmcomprandy wrote:A 700 horsepower everyday streetable 545 engine will probably be under 6,000 RPM.
the heads are ported to the intake .
mac460
mac460
Post  fc2444 February 16th 2011, 8:45 pm
Kenny Ford at PTC on converter.
fc2444
http://amr-coatins.com
Post  mac460 February 18th 2011, 4:01 am
so what kind of stall speed am i looking at ?
so to geto my hp am i going to be killing valve springs also ?
mac460
mac460
Post  mac460 February 21st 2011, 12:24 am
what do you think of comp cams xr 2924-10.
what do the rest of you think
mac460
mac460
Post  cool40 February 21st 2011, 12:42 am
i'd ditch the scorpion rockers.JMO. Very Happy
Post  mac460 February 21st 2011, 9:34 am
cool40 wrote:i'd ditch the scorpion rockers.JMO. Very Happy
why do you say that?
mac460
mac460
Post  cool40 February 21st 2011, 11:09 pm
poor quality,unless they have changed in the last couple of years.
Post  quick 52 February 21st 2011, 11:26 pm
x2 why do u say that
quick 52
Post  cool40 February 22nd 2011, 12:10 am
i did'nt care for the set on another guys car.the rockers would not clear the springs and were replaced with crane,no problems.you get what you pay for,most of the time. Laughing
