s and w powerglide adp plate
bigblockpaul
any body use the plate to adapt the bbf to glide?i need to know the thickness of the three gold spacers that go on the converter bolts.lost mine when bolts sheared off and they want 70 bucks to get new ones...thanks ..
bigblockpaul- Posts : 42
Re: s and w powerglide adp plate
gawdam! i'd buy a jw bell before i did that.you cant bolt it together and measure it? i never used one so i realy aint any help i run a reid glide.
You can space it with grade 8 washers, or have a machine shop cut you the spacers you need at the exact length. Its just a spacer and the bolts do the clamping. I would call another converter company. $70 is crazy
Curt- Posts : 2791
Make Sure you push conv all the way in the pump and pull out about 1/8 to 3/16 measure the distance to the flex plate shim with harden washers with grade 8 bolts I used lock nut s also on mine and go beat on some CHebbys $70
BIGDOG466- Posts : 265
yup
was beating alot of chevys the day the bolts sheared off and lost my spacers.iam just going to put it together and use washers and this time grade bolts...lol
bigblockpaul wrote:was beating alot of chevys the day the bolts sheared off and lost my spacers.iam just going to put it together and use washers and this time grade bolts...lol
Use grade8 washers also.
342g- BBF CONTRIBUTOR
cqan is .375 but slide the converter all the way in the pump and measure from flexplate to converter use a drill bit its easy to use to measure use the end that goes in the chuck then subtract .125 to .150 then use a washer stack up with grade 8 bolts
dragweek quickest street rod
2009 2010
2009 2010
quick 52- Posts : 612
» Powerglide adapter plate or BBF bellhousing
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» Cam thrust plate and water pump baking plate questions
» BBF Starter Locator Plate and Steel Mid Plate
» wtb front engine plate and mid plate
