converter pilot bushing
Who makes a ring to go around the converter pilot to go from 1.375 to 1.850. The converter I have doesn't have the wider pilot near the face of the converter.
Casey
Casey
8liter- Posts : 202
Re: converter pilot bushing
Bigdog466, is a real handy fellow.
And from experience, don't run it without it, makes a mess.
342g- BBF CONTRIBUTOR
[quote="8liter"]Who makes a ring to go around the converter pilot to go from 1.375 to 1.850. The converter I have doesn't have the wider pilot near the face of the converter.
Casey[/quote
Any common lathe operator
Casey[/quote
8liter wrote:
In other words get in touch with Bigdog466..........he can make you one.............unless you have a local that you trust to do it for ya.
8liter wrote:
You didn't catch what I meant, I didn't want to vollunteer him for anything, he made one for me worked like a glove, had to grind the snout about 1/32, and that was it.
Ok, thanks guys....
8liter- Posts : 202
Whats up 8liter? I made one for Harold I guess it fit. I bought one for my glide to 1.375 crank from Jegs JW made it I made Harlods from and piece of bronze I think. All it is is a spacer need to make it about a .001 larger that the crank ID and make the ID of spacer .004/.003 larger than pilot on converter. I made Harolds a little long cause I didn't have his crank or conver anybody with a lathe and material could make one. Make a little long to trim to the length you want.
BIGDOG466- Posts : 265
BIGDOG466 wrote:Whats up 8liter? I made one for Harold I guess it fit. I bought one for my glide to 1.375 crank from Jegs JW made it I made Harlods from and piece of bronze I think. All it is is a spacer need to make it about a .001 larger that the crank ID and make the ID of spacer .004/.003 larger than pilot on converter. I made Harolds a little long cause I didn't have his crank or conver anybody with a lathe and material could make one. Make a little long to trim to the length you want.
It worked great dog, I only ground about 1/32 off it, won't be long til race time, GOT TO GET A MOVE ON IT.
» Pilot bushing
» c6 pilot bushing issue
» Pilot Bushing Confusion-Need Help
» early morning tech help! pilot bearing/bushing
» 9.5 inch C6 converter 1.375 pilot
