racing pump gas
racing pump gas
this is the old tk7 additive google BND automotive look at the site i use the fuel additive when spraying my truck my buddy uses it in his procharger car and told me about it work good with higher comp. engine on pump gas instead of race gas prices just add 30 cents to pump gas per gal.
dragweek quickest street rod
2009 2010
2009 2010
quick 52- Posts : 612
Re: racing pump gas
what happened to the tk7 people.............
jc10000rpm- Posts : 193
Re: racing pump gas
same guy had to change the name of additive google give them a call $hit does work but pricey
2009 2010
2009 2010
Re: racing pump gas
are u sure same guy?? he used to be in oklahoma city........... Mr. Tel was his name, i knew some of the people that helped distribute his stuff in the early 90's
Great Products !!!!!!!!!!
Re: racing pump gas
no i'm not sure but was told it was all i know is that it works have 4 friends that use it with a lot more motor than i have 2 have 11.5 comp. one is at 13.0 the other is a procharger i'm at 10.3 i use it at drag week and when i spray the one friend has 11.5 comp and sprays 175hp with it on 93 pump gasjc10000rpm wrote:are u sure same guy?? he used to be in oklahoma city........... Mr. Tel was his name, i knew some of the people that helped distribute his stuff in the early 90's
2009 2010
» Christmas Bench Racing - A460 572 Pump Gas Hydraulic Roller @800+ hp?
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
» smog pump for a vacum pump
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
