New Engine Has Miss
New Engine Has Miss Empty New Engine Has Miss
Post  g612gr February 17th 2011, 7:35 pm
I just put together a new motor 466 ci. For some reason I have a miss.....first it was on 1 & 8. come to find out the New Petronix dist I bought was bad. put MSD 8350 in this afternoon....now I still have #1 not firing ??? Put different plug in it using (AGSP32).....different plug wire...I think the valves are adjusted correctly...going to check that later....have 160 lbs compression on it....I put SCJ Heads from BV Evans on it. Sounds great for 7 cylinders. Would prefer eight Very Happy I'm running a Edelbrock Air Gap intake.....Demon carb....750.....I wonder/think #1 isn't getting any fuel? Don't really make any sense that it wouldn't be? I'm running out of ideas here.....any suggestions would be appreciated.
g612gr
g612gr
New Engine Has Miss Empty Re: New Engine Has Miss
Post  4thHorseman February 17th 2011, 8:02 pm
So have you confirmed #1 is getting spark? How do you know its #1 that's missing?
What intake? Why would you suspect only 1 cylinder was so lean it wouldn't fire off?
4thHorseman
4thHorseman
New Engine Has Miss Empty Engine Miss
Post  g612gr February 17th 2011, 8:53 pm
Pulled off # one plug wire and it doesn't change feel of motor....pull all the other one and you can feel the cylinder drop. Pulled the plug and it didn't look like it had been firing?? Plug is getting spark. Pulled it out and grounded it to see if it was sparking. ..Intake is an Edelbrock Air Gap. Nothing I can think of makes any sense?
g612gr
g612gr
Post  bb429power February 17th 2011, 8:56 pm
Are you 100% sure the valves in the #1 cylinder are opening?
bb429power
bb429power
Post  cobra501 February 17th 2011, 9:40 pm
x2 on valves if you have spark.
cobra501
cobra501
New Engine Has Miss Empty Valves Opening
Post  g612gr February 17th 2011, 9:49 pm
I checked compression and it was 160.....I am going to pull the V-Cover and check the adjustment tomorrow....so 100% sure.....probalbly 99% sure they are opening. Could I still have good compression if they weren't opening.
g612gr
g612gr
Post  bb429power February 17th 2011, 9:51 pm
Yes you could. If it were me I would pull he valve cover off and let it idle, just watch. You'll know if the valves aren't opening real quick...
bb429power
bb429power
Post  jbozzelle February 19th 2011, 11:14 am
bb429power wrote:Yes you could. If it were me I would pull he valve cover off and let it idle, just watch. You'll know if the valves aren't opening real quick...
Nope. Pull the vc and check it before you run it again. Might be a bent pushrod. But if it's not bent yet it may bend when you light it off again. Don't roll the dice.
Post  bb429power February 19th 2011, 11:19 am
I know before, we took a plastic hammer to the valves to see if they were stuck on the seat. What happened was we bent a pushrod and we didn't know what was going on until we ran it with the v/c off and saw 2 rockers weren't moving. But yeah you could check it without starting it...But I figered the problem is already there, so it would have already bent IF that's the problem and if it isn't it wouldn't bend. But I see your logic.
bb429power
bb429power
