Looking for a stock small block 164th bell for a c4
342g
nuclearcobra
Looking for a stock small block 164th bell for a c4 Empty Looking for a stock small block 164th bell for a c4
Post  nuclearcobra February 21st 2011, 6:06 pm
you guys got any laying around ?
Last edited by nuclearcobra on February 21st 2011, 7:32 pm; edited 1 time in total
nuclearcobra
nuclearcobra
Looking for a stock small block 164th bell for a c4 Empty Re: Looking for a stock small block 164th bell for a c4
Post  342g February 21st 2011, 6:21 pm
Not sure what you are looking for, I have a bell that will bolt a c-4 to a big block, but it won't certify.
342g
342g
Post  nuclearcobra February 21st 2011, 7:31 pm
I forgot a bellhousing for a small block ford, and a factoy one is fine its not for a fast car.
nuclearcobra
nuclearcobra
Post  342g February 21st 2011, 8:22 pm
Can't help with small block.
342g
342g
Post  TravisRice February 21st 2011, 8:31 pm
Brian,
I am real sure I have one. If I do it is yours for shipping. Does the one you need bolt through the pump or does it bolt around the pump??
Travis 301-707-3462
Post  jbozzelle February 22nd 2011, 1:27 am
164 tooth bolts to the case, right? I'll check and see if I have one.
Post  Maddmattmustangs February 22nd 2011, 1:43 am
Oh I just gave mine away yesterday Sad
I'll see if I can get it though
Maddmattmustangs
Maddmattmustangs
Post  nuclearcobra February 22nd 2011, 4:53 am
It bolts through the pump Travis and John i'm not sure if 164th bells are case mounted i thought the 157 and 164's were both pump mounted ? with the exception of certain ones made for case mounting and thanks matt also.
nuclearcobra
nuclearcobra
Post  Gregaust February 22nd 2011, 6:27 am
nuclearcobra wrote:It bolts through the pump Travis and John i'm not sure if 164th bells are case mounted i thought the 157 and 164's were both pump mounted ? with the exception of certain ones made for case mounting and thanks matt also.
There are some bells for 164 tooth that bolt through the pump for case fill. My understanding is they were quite rare . More common is the 164 that bolts to the case .
Gregaust
Post  nuclearcobra March 3rd 2011, 9:01 am
Thanks guys for checking but i found what i needed tci sells factory refurbished non sfi 164th bells in pump mount 513310 or case mount 513200 for 100 bucks Cool and the tech man at tci did say the 164th pump mounted bell is getting harder to find.
nuclearcobra
nuclearcobra
