better core support
bb429power
D's557BBF
better core support Empty better core support
Post  D's557BBF March 2nd 2011, 10:24 pm
Just wanted to know if someone makes a Radiator "core" support that is better then a stock one.
I have a 1987 mustang LX (race car only) and I want to upgrade the core support. It's pretty beat up right now!!
Thanks for your help!
D's557BBF
D's557BBF
better core support Empty Re: better core support
Post  bb429power March 2nd 2011, 10:33 pm
I don't remember the year range, but I do do know that NPD just added the newer style (like 80's/90's I think) mustangs to its parts list.
bb429power
bb429power
Post  schmitty March 2nd 2011, 11:04 pm
Is there a way to reinforce what is there? Maybe some flat iron or angle iron? Cool
Post  richter69 March 2nd 2011, 11:16 pm
I cut ours out of our 81 and just put a tube in between the framerails, had to fab all the mounts for the radiator etc...........not really a bolt in deal.
Post  D's557BBF March 2nd 2011, 11:21 pm
I cut one out of a 1987 today and when i got it home it wasn't as nice as it was at the junk yard! I just wanted to know if they made something real beefy for it. I will just make my own then.
thanks guys
D's557BBF
D's557BBF
Post  GTmustang March 3rd 2011, 9:06 am
Denaro: I got a real nice used one from Todd Wellborn @ prestigemustang.com in Atlanta. I was advised by friends not to use a Reproduction radiator support because of problems with weak welds on the repro stuff. I haven't decided on exactly I'm going to do with mine, so if you decide to have one built or modified let me know and I might get one like it. I need more room between my water pump and radiator fans and I was considering cutting the bottom out of the stock support and making a tube lower that allows the radiator to be moved under the support!
Gary
GTmustang
Post  BigBlockRanger March 3rd 2011, 9:51 am
Team-Z sells one of these if you do not want to or can't make one.
2" square tube ends fit nicely up inside of old core support and butt against the front bumper 'shocks'. It looks wonky in that pic for some reason.
better core support 163045_473571369484_687514484_5543594_232311_n
I attached the lower bumper cover to it with some gigantic zip ties.
better core support 155861_473571404484_687514484_5543595_7291502_n
better core support 157030_473571324484_687514484_5543593_1323304_n
Added lower rad mounts, trans cooler mounts and a gusset on each side where the bend is. Also made the little top mounts for the radiator.
better core support 155735_475487854484_687514484_5572954_1033849_n
New radiator position
better core support 72ydtv
Trans cooler, radiator and HHR electric fan all mounted.
better core support 155596_476016324484_687514484_5580660_6356751_n
