rod lenght
rod lenght
4.5'' stroke 10.300 block with 1 3/8 deck pacers is a 8.250 long rod possible? been doing some talkin on another forum and this rod lenght just seems to long? maybe not...eric
fatal addiction- Posts : 433
Re: rod lenght
with that combo your piston deck pin c/l would be .925 awfully short piston minus pin Dia would set you at .43 top thickness from the pin dia I would not even go there... so I would say Heck NO
4.5 / 2.25
8.25 rod
10.30 block + 1.375 plates= 11.67
pin dia .990 / 2 = .495
2.25 half stroke + 8.25 rod =10.50 crank and rod length + .495 wrist pin = 10.995 to the top of the wrist pin.....11.67 - 10.995 which leaves you .680 from the top of the wrist pin to top of the deck.....lets say .250 thickness of small end of the rod....so that leaves you .430 left for piston thickness not including the clearance for the rod.....where are you going to put any valve notches?
4.5 / 2.25
8.25 rod
the Coug- Posts : 3055
Re: rod lenght
the Coug wrote:with that combo your piston deck pin c/l would be .925 awfully short piston minus pin Dia would set you at .43 top thickness from the pin dia I would not even go there... so I would say Heck NO
4.5 / 2.5
8.25 rod
2.25 half stroke + 8.25 rod =10.50 crank and rod length + .495 wrist pin = 10.995 to the top of the wrist pin.....11.675 - 10.995 which leaves you .680 from the top of the wrist pin to top of the deck.....lets say .250 thickness of small end of the rod....so that leaves you ..430 left for piston thickness not including the clearance for the rod.
Fixed the math for ya Coug. Still pretty slender stuff.
schmitty- Posts : 4538
Re: rod lenght
what heads?
Something in the 8" range would work and give you a 1.250 pin height.
Re: rod lenght
a-460dfree383 wrote:what heads?
Re: rod lenght
fatal addiction wrote:a-460dfree383 wrote:what heads?
What are you hoping to gain? Honestly a 4.5 stroke and deck plate is kinda a waste of time IMO, if your going to spend the time putting deck plates on put an arm in it....... the 4.500 / 6.800 / 10.300 combo works fine.
Re: rod lenght
it was a conversation from another forum i'm not doing this. the debate was if a 8 1/4'' rod would fit in a 10.300 block with 1 3/8'' deck plates. my math says no but just wanted to get some of your oppinions...ericdfree383 wrote:fatal addiction wrote:a-460dfree383 wrote:what heads?
» Intake runner lenght
» crankshaft front snout lenght
» Rod Lenght Question on Oliver rods
» mustang 95 back half lenght shock
