Kobalt electronic caliper check bore size?
Kobalt electronic caliper check bore size? Empty Kobalt electronic caliper check bore size?
Post  bigjohn2007 March 6th 2011, 6:57 pm
what should it show if the bore is 0.60 if it will even work
bigjohn2007
bigjohn2007
Kobalt electronic caliper check bore size? Empty Re: Kobalt electronic caliper check bore size?
Post  DFI429 March 6th 2011, 7:14 pm
Stock bore is 4.360... and if you mean .060 (not .60) it will be around 4.020
DFI429
DFI429
Post  bigjohn2007 March 6th 2011, 7:31 pm
DFI429 wrote:Stock bore is 4.360... and if you mean .060 (not .60) it will be around 4.020
yes that my bad thanks for the help man
bigjohn2007
bigjohn2007
Post  DFI429 March 6th 2011, 7:34 pm
No prob... Calipers are good for a check "at a distance"... If you want to "blueprint" your own stuff pick up a dial bore gauge and a decent micrometer set Wink
DFI429
DFI429
Post  bigjohn2007 March 6th 2011, 7:38 pm
you know part # in summit or jegs
bigjohn2007
bigjohn2007
Post  IDT-572 March 6th 2011, 9:34 pm
4.360 + .060 = 4.420 Wink
Post  richter69 March 6th 2011, 9:38 pm
Snake is a mathematician among other things..............
Post  bigjohn2007 March 6th 2011, 9:53 pm
dam i can do this so 4.360 + .030 = 4.390 right
bigjohn2007
bigjohn2007
Post  IDT-572 March 6th 2011, 10:27 pm
bigjohn2007 wrote:dam i can do this so 4.360 + .030 = 4.390 right
Cool
Post  DFI429 March 7th 2011, 2:11 am
Lol...duh.... drunken
DFI429
DFI429
